Thinking of buying an Aeon Z-stick Gen5, Does all sensors work?
burton666
I am planning on buying an Aeon Z-stick Gen5 to use with domotiz. But does all z-wave products work with domoticz? I am mostly interested in those multisensors that aeon-labs sell.
juankar
- Domoticz version: 4.
Re: Thinking of buying an Aeon Z-stick Gen5, Does all sensors work?
I can say that these modules Works fine
Qubino ZMNHBD1 (2 Flush Relays switch) (ZWave Plus)
POhilio PAN04 (ZWave)
Fibaro Multisensors (Zwave)
Bye
Bye
tinidk
Aeon labs multisensor 6 works fine.
burton666
Also does it matter if I buy a RaZberry or a Aeon Z-stick? Are there any advantages using any of them?
Kerneldomoticz
- Domoticz version: 3.5248
So far Z-stick gen5 i'm facing 2 issues :
- Fibaro wall plug does not take the OFF & ON colours i set in parameters.
- Fibaro Smoke detector goes Dead after a server reboot.
-Fibaro Door switch : potential problem as when i set security panel password i have an error ib logs that refer to this door switch node and security panel never show up.
so fare I've posted here for the fibaro wall plug, but no answers. i'm planning to take it out from the zwave network and back in to see the difference.
smoke detector i will try the same as wake them up while healing the network.
and i'm under BETA version 3.5248
With The RAzberry card not all those problems but i found the Z-stick better in performances and stability.
Flo
Flo
