Set specific IP for Domoticz to use
jjbstolk
Domoticz version: Beta's
Post by jjbstolk »
On my Ubuntu server I have multiple IP's I would like domoticz to listen to 1 of those IP's. How can I do this?
Domoticz on RPI3
RFXCom 433 USB
jjbstolk
Re: Set specific IP for Domoticz to use
Post by jjbstolk »
I was hopeing for a simple solution... in Apache it's possibble toset the IP and Port on which the server is actieve , you can do the same in NGIX,
May I can do the same with a proxy setup: https://www.domoticz.com/wiki/Secure_Nginx_Proxy_Setup
Domoticz on RPI3
RFXCom 433 USB
jjbstolk
Post by jjbstolk »
Ik do not wont to block, ik have 2 webservice's which I both want to run on the same server. It is not a security matter.
Domoticz on RPI3
RFXCom 433 USB
jjbstolk
Post by jjbstolk »
Does iptables filter based on fqdn?
Domoticz on RPI3
RFXCom 433 USB
pepijn
Post by pepijn »
Use the command line option -wwwbind
For example:
domoticz -wwwbind 192.168.0.20
