Make save_energy_script more efficient
remb0
Post by remb0 »
I have a script to save some money.
I have a virtual switch that's set saving(besparing) on/off (or saving or manual)
my wish:
when nodody is home some lights must off.
when somebody is home some lights must not on for longer then x
when it's in the middle off the day some lights but never go on.
I have tried the code below and it's working. but it's not really smart and efficient.
My question is if other people have tips for making the code smaller and efficient. and also more modular so other users can obtain it more easy (rename some variables instead of lots of hardcoded names.)
-- Save money
		package.path 	= package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
		My 				= require('MyFunc')
	-- Variable
		Script		  	= 'Besparing'						--
		Version       	= 1							--
		Notifications 	= uservariables["Notifications"] -- On/Off
		minuten_toegestaan	=	15 -- aantal minuten 180 = 3 uur
		StateDevice 	= 'Iemand_thuis'
		TH_Hour1        = 8		-- Treshold hour
		TH_Hour2        = 10		-- Treshold hour
		Nu_Hour			=tonumber(os.date('%H',time))
		LastChange_Gang			=otherdevices_lastupdate['Gang']
		LastChange_Slaapkamer	=otherdevices_lastupdate['Slaapkamer']
		LastChange_Trapgat			=otherdevices_lastupdate['Trapgat']
		Debug = 'Y'
		if ((Nu_Hour >= TH_Hour1) or (Nu_Hour <= TH_Hour2)) then Res_Hour=1   	else Res_Hour=0  end
		if (otherdevices['Slaapkamer'])  == 'On'   	        then Slaapkamer=1  	else Slaapkamer=0 end       -- omgedraait omdat het ook DO set dimmer level to 80% kan hebben ipv on.
		if (otherdevices['Gang']) 		 == 'On'	        then Gang=1   	    else Gang=0 end
		if (otherdevices['Trapgat']) 		 == 'On'	    then Trapgat=1   	else Trapgat=0 end
		if (otherdevices['Iemand_thuis']) 		 == 'On'	    then Aanwezig=1   	else Aanwezig=0 end
		TDiffGang		= My.Round(My.TimeDiff(os.time(),LastChange_Gang)/60,0)
		TDiffSlaapkamer = My.Round(My.TimeDiff(os.time(),LastChange_Slaapkamer)/60,0)
		TDiffTrapgat 	= My.Round(My.TimeDiff(os.time(),LastChange_Trapgat)/60,0)
	--logging
			print ('______________________________________________________________________')
			print('<b style="color:Blue"> '.. Script .. ".......v" .. Version .. "..Debugging=  " .. Debug .. '</b>')
			if (otherdevices['Bespaar_modus']) == 'Off' then 	print (".  Besparing wordt niet toegepast. ") 	goto done end
		if Debug == 'Y' then
		    print ( ".  " .. Aanwezig .. " - Iemand thuis? " )
			print ( ".  " .. Slaapkamer .. " - Slaapkamer " )
			print ( ".  " .. Gang .. " - Gang" )
			print ( ".  " .. Trapgat .. " - Trapgat" )
			print ( ".  " .. Res_Hour ..   " - Tijd  :    " .. Nu_Hour .. " <= "            .. TH_Hour1 .. " and " .. Nu_Hour ..  " >= " .. TH_Hour2 )
			print ( ".   Gang  :    " .. TDiffGang .. " minuten geleden naar: "             .. (otherdevices['Gang']) )
			print ( ".   Slaapkamer :    " .. TDiffSlaapkamer .. " minuten geleden naar: "  .. (otherdevices['Slaapkamer']) )
			print ( ".   Trapgat :    " .. TDiffTrapgat .. " minuten geleden naar: "        .. (otherdevices['Trapgat']) )
		IetsAan = Slaapkamer + Gang + Trapgat
	-- Binnen gestelde tijd
			if ((IetsAan >= 1) and (Res_Hour==1)) then
					if ((TDiffSlaapkamer > minuten_toegestaan) and (TDiffSlaapkamer < minuten_toegestaan+10)) and (Slaapkamer==1) then
    					commandArray['SendNotification']='Bespaaralert!#Slaapkamer staat al ' .. minuten_toegestaan .. ' minuten aan!#0#pushover'
    					print(".  Slaapkamer staat al " .. TDiffSlaapkamer .. " minuten aan.  Minuten_toegestaan = " .. minuten_toegestaan .. ".")
    					commandArray['Slaapkamer']='Off'
						if ((TDiffGang > minuten_toegestaan) and (TDiffGang < minuten_toegestaan+10)) and (Gang==1) then
    						commandArray['SendNotification']='Bespaaralert!#Gang staat al ' .. minuten_toegestaan .. ' minuten aan!#0#pushover'
    						print(".  Gang staat al " .. TDiffGang .. " minuten aan.  Minuten_toegestaan = " .. minuten_toegestaan .. ".")
    						commandArray['Gang']='Off'
							if ((TDiffTrapgat> minuten_toegestaan) and (TDiffTrapgat < minuten_toegestaan+10)) and (Trapgat==1) then
    							commandArray['SendNotification']='Bespaaralert!#Trapgat staat al ' .. minuten_toegestaan .. ' minuten aan!#0#pushover'
    							print(".  Trapgat staat al " .. TDiffTrapgat .. " minuten aan.  Minuten_toegestaan = " .. minuten_toegestaan .. ".")
    							commandArray['Trapgat']='Off'
		if ((Aanwezig == 0) and (IetsAan >= 1))  then
		    print(".  Niemand thuis terwijl" .. TDiffSlaapkamer .. " aan stond.")
		    commandArray['SendNotification']='Bespaaralert!#Niemand aanwezig en devices aan!#1#pushover'
		    commandArray['Alles']='On'
::done::
:idea:
gerard76
Domoticz version: 3.8153
Re: Make save_energy_script more efficient
Post by gerard76 »
Well, most of the script is prints and debug. I understand this is useful while developing, but when you know the script works you can remove the debug code. The core could be:
devices = { 'Gang', 'Slaapkamer', 'Trapgat' }
for i, device in pairs(devices) do
  state_duration = My.TimeDiff(os.time(), otherdevices_lastupdate[device]) / 60
  if otherdevices[device] ~= 'Off' and state_duration > max_minutes and state_duration < max_minutes + 10 then
    commandArray['SendNotification'] = 'Bespaaralert!#'..device..' staat al ' .. max_minutes .. ' minuten aan!#0#pushover'
    print(".  "..device.." staat al " .. state_for .. " minuten aan.  Minuten_toegestaan = " .. max_minutes .. ".")
    commandArray[device] = 'Off'
Other tips could be:
  • StateDevice - is not referenced from the code
    if ((Nu_Hour >= conserve_from) or (Nu_Hour <= conserve_till)) -- EVERY hour is > 8 OR < 10, I think you mean 'and' in stead of 'or'
    Debug = 'Y' -- you use this as a boolean, so better make it true/false
    goto done -- might as well return, then you know it exits when you read that line in stead of scrolling to ::done::
    Variable naming could be better. StateDevice => somebody_home, TH_Hour1, TH_Hour2 => conserve_from, conserve_till, Nu_Hour => now, etc
    I have just started with lua 2 weeks ago, so I am not sure about convention, but usually its CamelCase or under_scores for variable names, but not both.
