How to get idx for z-wave (RGBW) controller
Shaggie_NB
Post by Shaggie_NB »
I wanted to try the following command for my Fibaro RGBW device:
To use the animation program Storm on this device.
But I don't know which number to use for the idx?
Is it derivable from the node number? In my case: 004 (0x04) or is it something else?
Can anybody help me? :oops:
sijones
Domoticz version: Git
Re: How to get idx for z-wave (RGBW) controller
Post by sijones »
Go to devices and look for it in the list, the idx is on the left.
sijones
Post by sijones »
I've moved this as it's not a bug or problem just a use case question. Please make sure you look for the correct place to create a thread.
Shaggie_NB
sijones wrote:Go to devices and look for it in the list, the idx is on the left.
I'm working a lot with domoticz and I know how to work with JSON en idx......
But the RGBW controller isn't a device in the devicelist, because it's a zwave node.
So again my question: wich idx to use for changing the parameters of the node?
(because this isn't so simple and it's not in the wiki or anything, for me it's a bug or at least a problem!)
gizmocuz
Post by gizmocuz »
It is also a device in the devices table
Shaggie_NB
Thnx gizmocuz!! it's working!!
I looked in the table ZWaveNodes and saw the following data for the Fibaro RGBW:
ID=1, HardwareID=14, HomeID=25487939, NodeID=4
If you want to see the configpage of the device you must use the HardwareID:
http://[ipadres]:[portnumber]/json.htm?type=openzwavenodes&idx=14 (at the end you see the idx)
If you want to change the animation setting to Storm you must use the ID:
http://[ipadres]:[portnumber]/json.htm?type=command&param=applyzwavenodeconfig&idx=1&valuelist=72_Nw%3D%3D
@gizmocus: Is it possible to show these values on the device-page? It would be a lot easier to find... :oops:
Egregius
Domoticz version: v2024.7
Post by Egregius »
If you click the device you should see it's settings below the table.
Shaggie_NB
Egregius wrote:If you click the device you should see it's settings below the table.
But do you also see the different idx's to use for the JSON commands.... I don't :shock:
And in the devicetable you don't see the RGBW controller itself (with idx=14 in my case)
Egregius
Post by Egregius »
No, but you do when you enable developer mode in your browser.
That way you also see the complete command that is sent. Lot's more than just one value.
example:
http://192.168.0.10:8084/json.htm?type=command&param=applyzwavenodeconfig&idx=31&valuelist=1_MTA=__2_MTU=__6_MzA=__9_MjAw__14_MjU1__16_MA==__20_MTU=__22_MzA=__26_MA==__40_MA==__42_MA==__60_MA==__62_MA==__64_MA==__66_MA==__81_NTA=__82_MTAw__83_MTAwMA==__86_MTk=__87_Mjg=__2000_NzIwMA==__3_MiBwdWxzZXM=__4_MTIgc2Vjb25kcw==__8_UElSIHNlbnNvciBhbHdheXMgYWN0aXZl__12_QkFTSUMgT04gYW5kIEJBU0lDIE9GRiBjb21tYW5kIGZyYW1lcyBzZW50IGluIEJhc2ljIENvbW1hbmQgQ2xhc3Mu__24_VGFtcGVy__80_TG9uZyBibGluaywgdGhlbiBzaG9ydCBibGluaywgTEVEIGNvbG91ciBkZXBlbmRzIG9uIHRoZSB0ZW1wZXJhdHVyZS4gU2V0IGJ5IHBhcmFtZXRlcnMgODYgYW5kIDg3Lg==__89_TEVEIGluZGljYXRlcyB0YW1wZXIgYWxhcm0u__
Shaggie_NB
Egregius wrote:No, but you do when you enable developer mode in your browser.
Oooh Thnx!!!
I didn't know that. But it is really very handy!!
I'm not so familiar with all this web-stuff..
