DragonBoard
soligloo
DragonBoard
Post by soligloo »
I'm new on Domoticz and I try to make my house connected with IoT (Internet of Things). For example, I would like to connect the heater with my phone so I can control the temperature via an application. I would like to do many others things too, like connect the fans, the doors... So I would like some advices.
First, I would like to know the difference between Raspberry Pi and DragonBoard 410c. I think they have the same utility, but I'm not sure.
Then I think I've found a scheme that would resolve the problem :
I connect sensors with a transceiver.
The transceiver transmits the information to Raspberry Pi (or DragonBoard...). Then it transmits to the platform one the phone of the user.
Then Raspberry receives from the user, and transmits to the transceiver, which transmits to the controler.
Do you think is it possible ? Do you have advices ?
Thanks,
SB.
gizmocuz
Re: DragonBoard
Post by gizmocuz »
There is no network plug on the dragonboard which makes it (for me) totally useless.
you can also have a look at the odroid-c2
