SCS317 setpoint gets updated on start, not after that
JayKudo
Post by JayKudo »
I have an SCS317 as thermostat, and its working pretty good thanks to domoticz, open-zwave and a razberry. There is just one thing that is annoying and should be solvable. The setpoint on the thermostat is reporting the correct setting in domoticz/open-zwave, but does not get updated if I change it physically om the thermostat itself.
When I restart domoticz, it retreives the correct setpoint again. So the thermostat can report the correct setpoint, however it does not get updated in open-wave unless I restart domoticz.
Is there any poll setting or otherwise which I can use to update the setpoint if it has been changed on the thermostat (The temperature on the thermostat gets updated nicely in domoticz) ?
JayKudo
Re: SCS317 setpoint gets updated on start, not after that
Post by JayKudo »
Little digging found that a 'Refresh Node Info' does retrieve the correct setpoint value. But no automatic/periodic update, anybody got an idea?
Richie1972
Post by Richie1972 »
Same problem I'm having with the Hostmann ASR-ZW Boiler receiver.
I'm trying to see if there's any way i can regularly run an automatic refresh of that node via a script, but not found anything yet :(
Richie
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
AxelvanH
Domoticz version: 2020.01
Post by AxelvanH »
On who's door do we have to knock to get support for these Horstmann Z-wave devices?
