Fibaro FGMS-001 no routed connection
Posted: Tuesday 05 April 2016 12:56
by d3rax
I want to place my Fibaro FGMS-001 in the hall way. When I do a range test it indicates that m-sensor cannot directly connect to the controller. I have also a Fibaro Smoke detector FGSD-002 (z-wave plus) in the hall way that is directly connect to the controller.
The m-sensor should make a routed connection via the smoke detector with the controller, right?
The range test of the m-sensor tries to make a routed connection (blinks yellow), but fails. I get two purple flashes and then a red light.
Here is a screenshot of my z-wave network.
Schermafbeelding 2016-04-05 om 12.36.35.png (81.59 KiB) Viewed 602 times
Hope you guys have a suggestion.
Re: Fibaro FGMS-001 no routed connection
Posted: Tuesday 05 April 2016 13:11
by jvdz
In general battery powered devices will go into a sleep and will not act as router in a Z-wave network.
You probably need a couple of powered devices to build a stable zwave mesh network.
Jos
