AEOEZW090-C Aeon Labs USB Stick & problems with Fritzbox
brainpaincgn
Domoticz version: 3.9052
Post by brainpaincgn »
my Domoticz installation was running well with the RFX433 until I added the above mentioned USB stick. Now I have to reboot my Cable router (AVM Fritzbox) three to four times a day. As soon as I shut down my Pi, removed the Z-Wave Stick and just used the RFX433, everything was working as it used to be again.
Can it be that the Z-Wave frequency is interfering with my Cable router?
Did this occur to someone else? I think those routers are pretty common in Germany.
Thanks in advance,
Sascha
brainpaincgn
gizmocuz
Re: AEOEZW090-C Aeon Labs USB Stick & problems with Fritzbox
Post by gizmocuz »
Not really, the DVB-C range is usually between 50 and 860Mhz
http://www.etsi.org/deliver/etsi_tr/101 ... 10101p.pdf
You do not power the raspberry via the Firtzbox i hope ? You also need a 2 Ampere power supply for the raspberry if you use both
brainpaincgn
Nope, the RasPi is powered over a dedicated power supply. A technician told me that those routers are very fragile to other frequences, if they are placed ro near to a TV, speakers, etc. But this could also be a lame excuse for almost every error...
Sascha
brainpaincgn
