Thermostat Override
pezhore
Thermostat Override
Post by pezhore »
Hello All,
I hope this is in the right place. My current Domoticz setup is running on a RPi 2 - I have a Nest and two temperature sensors (DHT22) - Nest is on the 1st floor of my townhome, one DHT22 is in the basement, the other is in my bedroom. I have also set up a dummy selector switch with several states:
  • > Off
    > Cool Basement
    > Heat Basement
    > Cool Bedroom
    > Heat Bedroom
My idea is to (based on the selector above) override the Nest - adjusting the setpoint to above what the Nest believes is the current temperature until the remote sensors have reached the original setpoint. A use case might look like this:
  • 1) Nest Setpoint: 65, Nest Temperature: 67, Basement Temperature: 61
    2) Heat Basement selected
    3) Nest Setpoint adjusted to 70 [Turning on heat]
    4) Basement Temperature rises to 63, Nest Temperature rises to 70
    5) Nest Setpoint adjusted to 75 [Basement still isn't at the target of 65 yet]
    6) Basement reaches 65, Nest Setpoint adjusted back to 65
The same affect would be achieved with the other potential settings (Cool Basement, Heat bedroom, etc).
I have rough pseudo-code in mind, but I need help hashing it out. This is just for Heat Basement, but could easily be adjusted for cool as well. Specifically, I'm unsure as to how to accomplish this in Lua/Python/Bash - and what specific API calls I can make (probably through curl).
Thoughts?
## Heat Basement
## Get our current, pre-mucking about Setpoint (e.g. target temperature)
Set $SetPoint equal to $Nest_Setpoint retrieved from API
## Turn up the thermostat
Increase $Nest_Setpoint by 5 degrees utilizing API
## Wait for potential changes
Wait 3 minutes
## Loop as long as the Basement sensor is reading less than the original target temperature
While $Basement_Temp is Less Than $Setpoint
	## If the Nest is reporting a temperature greater than the current setpoint (heat is not on), or if the nest can report if the system is not heating
	If $Nest_Temp is equal or greater than $Nest_Setpoint; or if $Nest_Heat is not on  ##Not sure how to check this
		## Increase our setpoint by another 5 degrees
		Increase $Nest_Setpoint by 5 Degrees
	Wait 3 minutes
	## Get the current temperature from the API
	Refresh Basement_Temp from API
Done
