Today I updated Domoticz to 3.4834 (latest stable) and after a few attempts I finally got the Qubino ZMNHDD1 dimmer working with the Aeotec S2 stick.
I included the node via the button on the stick.
Qubino ZMNHDD1 dimmer now working with Aeotec S2 stick
- bbqkees
- Domoticz version: 4.1x
- Egregius
- Domoticz version: v2024.7
Re: Qubino ZMNHDD1 dimmer now working with Aeotec S2 stick
Mine works several weeks now.
But dimlevel isn't always correct.
Example: dimlevel at 3%. I sent a off command, after that dimlevel is shown as 18% while the lamp is off. After a second off it shows off.
Same when switching off locally, dimlevel shows as 3% then.
Do you also notice that? Or should I empty that node from zwave conf file?
- bbqkees
I indeed notice the same behavior.
The 'old' dimmers are always correct.
- Egregius
Hmm, the config file hasn't changed in two months. Guess that exclusion/inclusion won't change a thing.
https://github.com/OpenZWave/open-zwave ... fig/qubino
Strange thing also: all other switches I have report correct status after refresh in OZWCP, this one doesn't.
Today I includes 2 domitech dimmable light bulbs and the behaviour is similar like described above. When switching on or off the dimming level is acting weird. And the icon is still showing the bulb as "on", only after switching off for the second time the icon shows "off"
When setting the dimlevel at 0% the bulb is switched off and the icon is showed accordantly.
I tried switching the polling on but then the dimmer value and on/status is also not ok. When the lamp is switched off is realy goes off but after some time it shows again as "on" with a certain dimming level.
Strange thing is that when switching via scene the lamp is switching fine but the Domoticz interface (icon and slider) is showing wrong status.
- bueno79
- Domoticz version: 4.9700
It seems this bug is still not fix. Do you know how to report it ?
regards
regards
