Opentherm problem OTGW: random number
For OpenTherm-gateway related questions in Domoticz
martjah
Post by martjah »
since a week i have a problem with my OpenTherm gateway but i cannot find any information about it. It worked great for over a year now and i haven't changed anything (except that the Heater has been shutdown last week).
Now i get the following messages:
2016-03-16 08:19:06.529 OTGW: T00090000
2016-03-16 08:19:06.529 OTGW: R007B0000
2016-03-16 08:19:06.530 OTGW: BC07B0143
2016-03-16 08:19:06.530 OTGW: AC0090000
2016-03-16 08:19:07.530 OTGW: T80190000
2016-03-16 08:19:07.531 OTGW: BC0193400
2016-03-16 08:19:08.532 OTGW: T10015A00
2016-03-16 08:19:08.532 OTGW: BD0015A00
2016-03-16 08:19:09.532 OTGW: T00000300
2016-03-16 08:19:09.533 OTGW: BC000030A
2016-03-16 08:19:10.533 OTGW: T90101480
2016-03-16 08:19:10.534 OTGW: R00740000
2016-03-16 08:19:10.534 OTGW: B4074B506
2016-03-16 08:19:10.534 OTGW: A50101480
2016-03-16 08:19:11.535 OTGW: T80190000
2016-03-16 08:19:11.535 OTGW: BC0193400
2016-03-16 08:19:12.536 OTGW: T10015A00
2016-03-16 08:19:12.536 OTGW: BD0015A00
2016-03-16 08:19:13.537 OTGW: T00000300
2016-03-16 08:19:13.538 OTGW: BC000030A
Can anyone tell me what that means?
It works via Opentherm.exe:
martjah
Re: Opentherm problem OTGW: random number
Post by martjah »
So i have a update, not a solution.
The "random" numbers are not random. It are the Opentherm messages that are the same as in the logging with OTmonitor.exe.
But i do not know why Domoticz cannot handle them. I did also update Domoticz to the latest stable version but that did not solve the problem.
Luigi87
Post by Luigi87 »
I had the same problem some time ago. From that moment i have set my OTGW aside. So i am also currious whats happening.
martjah
Post by martjah »
I've solved my problem :)
The OTGW was in an "unknown" state. If you open OTmonitor.exe and push F7, you can see the current mode and switch mode.
I tried switching to Gateway but the OTGW did not respond to that (neither the custom GW=1) command.
So i tried updating the firmware and i had to manually reset the unit, i unplugged the OTGW and plugged it back in and it jumped to "Gateway" mode.
The update afterwards but that's not an issue for me because i did not need to update it.
Luigi87
Post by Luigi87 »
martjah wrote:I've solved my problem :)
Right i will also try this soon. I hope my OTGW will work again. Have a lot of trouble with it :?
najtram
Domoticz version: v4.9700
Post by najtram »
I had the exact same issue.
First I tried to solve it this way:
- removed OTGW from hardware tab. (not sure if this was needed, bad thing is, the log is also deleted!!!)
- readded OTGW on hardware tab
- no result.
- deactivated OTGW in hardware tab.
Then:
- removed USB and power from OTGW.
- counted to 10 or 20, can't remember.
- reconnected OTGW
- reactivated OTGW in hardware tab.
Working!
RFLink Gateway → 433Mhz/KAKU switches
Z-Wave → Z-Stick Gen5+
ZigBee → ConBee II
Bluetooth → Soma Smart Shades
Opentherm Gateway → Remeha iSense - Tzerra boiler
ESP8266+CC1101 → ITHO ecofan RFT
P1 cable → DSMR 2.2+ Landys +gyr E350
LAN → Enphase Envoy
