Qubino Dimmer functions
royvanmarrewijk
Post by royvanmarrewijk »
I've bought a new house and at the moment I am testing the Domoticz platform to see if this works for me. My setup:
[*]Raspberry Pi 2
[*]Razberry Z-Wave Module
[*]Qubino Flush Dimmer (with push button)
[*]Qubino Flush Relay (with on / off switch)
Since I am planning to reduce the number of switches as much as possible I would like to know it the following scenario is possible with the Qubino Flush Dimmer in combination with Domoticz:
1. Dimmer Level = 0% && Single push -> Set Dimmer to 100%
2. Dimmer level > 0% && Single push -> Set Dimmer to 0%
3. Hold push button -> increase Dimmer level
4. Double Click push button -> Activate Scene.
Can you tell me if this is possible and if yes how to achieve this. If it ain't possible I would like to know if there are modules who can.
Kind regards,
Roy van Marrewijk
Egregius
Domoticz version: v2024.7
Re: Qubino Dimmer functions
Post by Egregius »
Double push is 100%
Single push is on/off.
Hold is dim down/up.
With a 2nd and/or 3th pushbutton you can activate scenes or other devices.
royvanmarrewijk
Hi Egregius,
Thanks for the conformation!
Roy
Gravityz
Domoticz version: 2022.2
Post by Gravityz »
i thought you said "reduce the number of switches"
with the qubino you need to hook up 2 more switches(so 1 switch on I1, second on I2 and third on I3)
as far as i can tell only the fibaro modules have a 2x and 3x click which you use to actrivate a scene.
They also have a I2 for hooking up a second switch which you can use for clikcnhold, single 2x and 3x click
