Domoticz on RPi and ESP8266 - Newbie
woody4165
Post by woody4165 »
Hi all
just installed Domoticz to an "old" RPi B+ and it seems to work good.
I have loaded ESP Easy fw on and ESP12-E module connected to a relay, configure it and created a simple Virtual Switch in Domoticz.
This is the config of ESP Easy connected to the ip address of the Rpi where Domoticz is istalled:
This is the configuration on Domoticz where the idx is 1, as in the ESP Easy config:
I've tried sending the command via http using this http://192.168.1.xx/control?cmd=GPIO,12,0 to the ESP and it's working.
Don't understand where is my error.
Can you please help?
Vittorio
maluko
Re: Domoticz on RPi and ESP8266 - Newbie
Post by maluko »
You are do a little confusing, only have to configurate the espeasy switch if you want put a fisic button/switch to control a switch on domoticz.
like you want you dont have to put anything on task at esp, only put the " http://192.168.1.xx/control?cmd=GPIO,12,0" on domoticz at "off action" and " http://192.168.1.xx/control?cmd=GPIO,12,1" at "on action".
Try it :)
woody4165
Post by woody4165 »
maluko wrote:You are do a little confusing, only have to configurate the espeasy switch if you want put a fisic button/switch to control a switch on domoticz.
Try it :)
It's working...
So when do I need to fill in the ESP Easy Devices tab?
Is it possible to set more than one command for a switch?
In my case I want to be sure that when I set ON a switch I have to set ON a GPIO and OFF another one.
Thanks again
Vittorio
deennoo
Post by deennoo »
Then you can use évents with blocky or Lua or scène.
http://domo-attitude.fr
woody4165
Post by woody4165 »
deennoo wrote:Then you can use évents with blocky or Lua or scène.
Thanks.
Where I can find some more info on Blocky or Scenes related to Domoticz?
toreandre
Post by toreandre »
When you are using sensors or switches.
woody4165
Post by woody4165 »
By switches you mean non-virtual switches?
woody4165
Post by woody4165 »
Thanks.
I have created an event like this:
do I need to connect with the switch or is it connected automatically?
I've tried to remove the http://.... from the On and Off action in the switch1 device, but it does'n work.
toreandre
Post by toreandre »
Real switches and buttons that is fysical connected to the gpio pins on the ESP.
I have several capacitive touch buttons connected to one of my esp's to activate scenes in domoticz.
deennoo
Post by deennoo »
Thanks.
just follow the wiki !
https://www.domoticz.com/wiki/Events
woody4165
Post by woody4165 »
toreandre wrote:
woody4165 wrote:
toreandre wrote: When you are using sensors or switches.
I tought was valid also for virtual switch.
I followed this guide http://www.esp8266.nu/index.php/Tutoria ... icz_Switch, but probably it doesn't work...
woody4165
Post by woody4165 »
deennoo wrote:
Thanks.
I created an event based on my virtual switch and put also a notification for Debug.
Simple If On else If Off.
It goes thru the notification (only if notification is before the url) and the real command I set is Open Url with http:// and the same url that was in the On Command and Off Command.
But when switch change the state, it doesn't turn On and Off the relay.
I tried first setting on the On state GPIO 12 to 0 and GPIO 13 to 1 (opposite for the Off Command).
Then I tried just to set one GPIO.
In the Blocky event before I just remve the notification since it's working.
In both cases it doesn't work, even if the notifications tells me that the event is running properly.
Any suggestion?
woody4165
Post by woody4165 »
Just tried a LUA script version of what I was looking for, but partially.
This is the LUA script:
print ("All based event fired");
-- loop through all the devices
for deviceName,deviceValue in pairs(otherdevices) do
    if (deviceName=='switch1') then
        if deviceValue == "On" then
            print("Device is On")
            commandArray['OpenURL'] = "http://192.168.1.xx/control?cmd=GPIO,12,0"
        elseif deviceValue == "Off" then
            print("Device is Off")
            commandArray['OpenURL'] = "http://192.168.1.xx/control?cmd=GPIO,12,1"
What I would like to do, if possible, is to manage two relays with the same command, in my case relay1 ON and relay 2 OFF when switch1 is On and the opposite when it's Off.
I cannot pass two CommandArray with OpenURL because the second will overwrite the first (if it works).
How can I do it?
In any case, the same thing done with Blockly, as in the previous post, doesn't work. Strange!!!
I get an error
Error: Error opening url: "http://192.168.1.xx/control?cmd=GPIO
it's missing the comma after GPIO and everything after the comma.
Is there a different way to pass the "," into an http string?
Can someone help?
EDIT:
Done it.
The issue was the comma in the url.
Just replaced the commas with %2c and now with Blockly works also with two consecutives OpenURL commands.
