Foscam FI9903P issue.
Posted: Thursday 10 March 2016 19:35
by Freddy315pk
I have a strange problem with a Foscam FI9903P ip camera and I am hoping someone here can help.
I can configure it and I get a picture with "Test Connection" button:
Foscam edit camera.jpg (91.75 KiB) Viewed 2806 times
But, there is no preview:
Foscam overzicht camera.jpg (153.64 KiB) Viewed 2806 times
If I click on the webcam icon, there is also no image:
Foscam voordeur camera.jpg (34.64 KiB) Viewed 2806 times
My other camera, a Foscam FI9818W V2, connected on the same lan-switch, does work.
Does anyone here have any idea what can possible be wrong?
The "voordeur" camera is linked to my kaku doorbell and is supposed to send a picture when pressed.
But because, I think, since there is no image, no picture is sent.
If I login to the camera through a web browser, everything is also fine.
Re: Foscam FI9903P issue.
Posted: Wednesday 23 March 2016 21:56
by oliviers
Just to say that I have exactly the same problem with a FOSCAM FI8910W.
This is not the solution to your issue, but at least, you're not alone....
Oliviers
Posted: Thursday 24 March 2016 22:34
by RutgerBo
I've a FI9903EP, and the stream is working fine, only the preview is taken from the other cam I have added first (Dericam m601w, a Foscam dome clone (640x480). But the image button is working.
Besided the username and password in the url, it's only working for me when I add both username and password in the desired fields too.
Posted: Friday 25 March 2016 9:07
by Freddy315pk
After some "tinkering" I got my camera working again.
When I updated to the latest beta version, my camera is working again. Tried to go back to the latest stable version, problem came back.
So I assume there is a bug in the latest stable version, latest beta version is working fine (3.5010).
Posted: Sunday 27 March 2016 16:29
by marmachine
Hi Freddy,
Did you also setup motion for your cam? (using your camera as motion sensor?)
I'm kinda stuck with that, however i have my camera FOSCAM FI9900P added to Domoticz.
Posted: Wednesday 12 July 2017 0:38
by nigels0
Late response - sorry, but the problem is the firmware. The call is returning the HTML response, not the image. Foscam knew about this and fixed it in the firmware - relatively recently.
