Edit database records
McFranky
Post by McFranky »
Is it possible to modify existing database records?
My kw/h counter has an incorrect value is entered and this corrupted me all the statistics. :?
Any ideas?
Greeting from Berlin
Frank
Greetings from Berlin...
Egregius
Domoticz version: v2024.7
Re: Edit database records
Post by Egregius »
I use sqladminer, a php page.
For windows there's Sqlite explorer I think.
Advantage of sqladminer is that it can be used without stopping domoticz.
Dnpwwo
Post by Dnpwwo »
A better way is to go to the device log within Domoticz itself and find the part of the graph with the bad value and click on the value while holding the shift key down. For many device types you will be asked if you want to delete the clicked data point.
McFranky
Post by McFranky »
OK. I try to click on the bad value with Shift Key in the Graph on 13.Feb. but nothing happens...
McFranky
Post by McFranky »
OK, it works. I take the chart for the last month...
Thanks for support
Users browsing this forum: Amazon [Bot] and 1 guest
