Door sensors and a timer.
Posted: Wednesday 09 March 2016 10:36
by golden07
I've added some door sensors (klikaanklikuit AMST-606) to my system as doorlock. This works fine, i see when a door is opend, and when the door is closed. But i want to set a timer for this. on the doorlock option is no option for timer. Is there another option so i can add timers to the sensors?
Re: Door sensors and a timer.
Posted: Wednesday 09 March 2016 10:39
by Slinkos
If you edit the switch you can set an "on delay". Is that what you want?
Posted: Wednesday 09 March 2016 14:06
by golden07
Slinkos wrote:If you edit the switch you can set an "on delay". Is that what you want?
thnx for your reply.
i don't want a delay, what i want is for example:
between 8 and 9 no notification if the door is opend
between 9:01 and 17:00 send notification if the door is opend.
between 17:00 and 18:00 no notification if the door is opend
Posted: Wednesday 09 March 2016 14:11
by Slinkos
You can configure that in your blocky event like this:
Posted: Wednesday 09 March 2016 14:20
by golden07
Thnx i wil try that.
