Q: how to run a avent/Script when a call is coming from Fritz!Box?
Albsucher
Post by Albsucher »
i own a Fritz!Box 7490 where also my doorbell is connected to.
I would like to have a notification (in my case i use Prowl) to be notified about a call from my doorbell or any incoming phone call - ideally together with the name of the phone number.
Did anyone of you already implement this or give me a hint how to do that?
I would be more happy with a Blocky event if ever possible as i am not a programmer and so far did nothing with LUA.
Thanks for any help!
Albsucher
Re: Q: how to run a avent/Script when a call is coming from Fritz!Box?
Post by Albsucher »
So far i managed to setup a notification when the FritzBox CallMonitor receives a "On" command that a call has been initiated.
But the more interesting is: how can i add the caller's number to this notification? Anyone an idea?
Albsucher
Post by Albsucher »
Still have problems sending a notification (Prowl) when a call is coming in.
I understand this could be done by firing an event when the "call" switch is started (done by the call monitor).
But do not have any clue how to add the senders phone number here?
Anyone an idea on this? May be a LUA script is possible?
