BTW: it's this topic that I'd like to have moved: viewtopic.php?f=11&t=10760
Can't send PMs? Topic is solved
mcwieger
- Domoticz version: 2020.1
Can't send PMs?
I posted a question in the Switches section, but it should probably be moved to the Scripts section. I tried to PM a moderator/administrator with this question, but the message is stuck in the Outbox. Is that an intended setting of this forum?
I moved to HomeAssistant. It was fun while it lasted!
- jvdz
- Domoticz version: 4.107
Re: Can't send PMs?
That's where is stays until read by the person you've send it to after which it is moved to "sent messages".
Jos
Jos
Slinkos
- Domoticz version: 3.4834
Re: Can't send PMs?
Ohhh... I also tought that the messages couldn't be send! Maybe it's better to change this or at least make that clear in the outbox..
