No status report from Mcohome MH-S314 Four-load
Pietoesnoe
Post by Pietoesnoe »
I asked the same question about a year ago. The situation is a bit different now and maybe it can be fixed?
I have Domoticz v2.4633 on my Synolgy 214. I have an MCO touch panel with 4 buttons. I can make the switch go on and off, but the touch panels sends no status reports from the switch to Domoticz. The switch should give status reports by putting the controller in group 5.
The Mcohome MH-S314 Four-load is (since a few months) also correctly reported in the Hardware menu. So I guess its correctly registered in Open Zwave and it is a problem within Domoticz itself? Is there any change this can be fixed?
The log gives some ‘status’ errors from time to time : 2016-03-02 07:37:25.403 OpenZWave: Received timeout notification from HomeID: 25486901, NodeID: 5 (0x05)
OpenZwave log:
2016-03-02 11:23:57.553 Always, OpenZwave Version 1.4.53 Starting Up
2016-03-02 11:23:57.553 Info, Setting Up Provided Network Key for Secure Communications
2016-03-02 11:23:57.553 Info, mgr,     Added driver for controller /dev/ttyUSB0
2016-03-02 11:23:57.553 Info,   Opening controller /dev/ttyUSB0
2016-03-02 11:23:57.553 Info, Trying to open serial port /dev/ttyUSB0 (attempt 1)
2016-03-02 11:23:57.564 Info, Serial port /dev/ttyUSB0 opened (attempt 1)
2016-03-02 11:23:57.565 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2016-03-02 11:23:57.565 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2016-03-02 11:23:57.565 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2016-03-02 11:23:57.565 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2016-03-02 11:23:57.565 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2016-03-02 11:23:57.566 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2016-03-02 11:23:57.569 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x32, 0x2e, 0x37, 0x38, 0x00, 0x01, 0x9b
2016-03-02 11:23:57.569 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2016-03-02 11:23:57.569 Info, contrlr,     Static Controller library, version Z-Wave 2.78
2016-03-02 11:23:57.569 Detail, Node045,   Expected reply was received
2016-03-02 11:23:57.569 Detail, Node045,   Message transaction complete
2016-03-02 11:23:57.569 Detail, contrlr, Removing current message
2016-03-02 11:23:57.570 Detail,
2016-03-02 11:23:57.570 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2016-03-02 11:23:57.572 Detail, contrlr,   Received: 0x01, 0x08, 0x01, 0x20, 0x01, 0x84, 0xe6, 0x35, 0x01, 0x81
2016-03-02 11:23:57.572 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0x0184e635.  Our node ID = 1
2016-03-02 11:23:57.572 Detail, Node132,   Expected reply was received
2016-03-02 11:23:57.572 Detail, Node132,   Message transaction complete
2016-03-02 11:23:57.573 Detail,
2016-03-02 11:23:57.573 Detail, contrlr, Removing current message
2016-03-02 11:23:57.573 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2016-03-02 11:23:57.575 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x05, 0x1c, 0xe3
2016-03-02 11:23:57.575 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2016-03-02 11:23:57.575 Info, contrlr,     There is a SUC ID Server (SIS) in this network.
2016-03-02 11:23:57.575 Info, contrlr,     The PC controller is an inclusion static update controller (SUC) and was the original primary before the SIS was added.
2016-03-02 11:23:57.575 Detail, Node227,   Expected reply was received
2016-03-02 11:23:57.575 Detail, Node227,   Message transaction complete
2016-03-02 11:23:57.576 Detail,
2016-03-02 11:23:57.576 Detail, contrlr, Removing current message
2016-03-02 11:23:57.576 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2016-03-02 11:23:57.582 Detail, contrlr,   Received: 0x01, 0x2b, 0x01, 0x07, 0x03, 0x07, 0x00, 0x86, 0x00, 0x02, 0x00, 0x01, 0xfe, 0x80, 0xfe, 0x88, 0x0f, 0x00, 0x00, 0x00, 0xfb, 0x97, 0x3f, 0x82, 0x07, 0x00, 0x00, 0x80, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x82
2016-03-02 11:23:57.582 Info, contrlr,  Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2016-03-02 11:23:57.582 Info, contrlr,     Serial API Version:   3.7
2016-03-02 11:23:57.582 Info, contrlr,     Manufacturer ID:      0x0086
2016-03-02 11:23:57.582 Info, contrlr,     Product Type:         0x0002
2016-03-02 11:23:57.582 Info, contrlr,     Product ID:           0x0001
2016-03-02 11:23:57.582 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2016-03-02 11:23:57.583 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2016-03-02 11:23:57.583 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2016-03-02 11:23:57.583 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2016-03-02 11:23:57.583 Detail, Node007,   Expected reply was received
2016-03-02 11:23:57.583 Detail, Node007,   Message transaction complete
2016-03-02 11:23:57.583 Detail, contrlr, Removing current message
2016-03-02 11:23:57.583 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2016-03-02 11:23:57.585 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x56, 0x01, 0xad
2016-03-02 11:23:57.586 Detail,
2016-03-02 11:23:57.586 Info, contrlr, Received reply to GET_SUC_NODE_ID.  Node ID = 1
2016-03-02 11:23:57.586 Detail, Node173,   Expected reply was received
2016-03-02 11:23:57.586 Detail, Node173,   Message transaction complete
2016-03-02 11:23:57.586 Detail, contrlr, Removing current message
2016-03-02 11:23:57.586 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2016-03-02 11:23:57.639 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x1e, 0xd9, 0x25, 0xa0, 0x0f, 0x8b, 0xef, 0x02, 0xb9, 0x34, 0xb4, 0x68, 0xb0, 0x26, 0xaf, 0x93, 0x0a, 0xe7, 0x71, 0xbf, 0x05, 0x5b, 0xaa, 0x01, 0xeb, 0x38, 0x4c, 0xef, 0x5f, 0x81, 0x09, 0x45, 0x02
2016-03-02 11:23:57.640 Detail,
2016-03-02 11:23:57.640 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2016-03-02 11:23:57.640 Detail, Node032,   Expected reply was received
2016-03-02 11:23:57.640 Detail, Node032,   Message transaction complete
2016-03-02 11:23:57.640 Detail, contrlr, Removing current message
2016-03-02 11:23:57.640 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2016-03-02 11:23:57.689 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x08, 0x1d, 0xf7, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x33
2016-03-02 11:23:57.689 Info, mgr,     Driver with Home ID of 0x0184e635 is now ready.
2016-03-02 11:23:57.690 Info,
2016-03-02 11:23:57.755 Detail, Node002, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.755 Detail, Node002, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.757 Detail, Node003, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.757 Detail, Node003, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.758 Detail, Node005, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.758 Detail, Node005, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.760 Detail, Node006, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.760 Detail, Node006, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.762 Detail, Node007, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.762 Detail, Node007, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.765 Detail, Node008, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.765 Detail, Node008, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.766 Detail, Node009, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.766 Detail, Node009, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.769 Detail, Node010, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.769 Detail, Node010, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.774 Detail, Node011, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.774 Detail, Node011, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.776 Detail, Node012, Queuing (Controller) Delete All Return Routes
2016-03-02 11:23:57.776 Detail, Node012, Queuing (Controller) Assign Return Route
2016-03-02 11:23:57.777 Info, Node009, EnablePoll for HomeID 0x0184e635, value(cc=0x25,in=0x00,id=0x01)--poll list has 1 items
2016-03-02 11:23:57.777 Info, Node009, EnablePoll for HomeID 0x0184e635, value(cc=0x32,in=0x00,id=0x01)--poll list has 2 items
2016-03-02 11:23:57.777 Info, Node009, EnablePoll for HomeID 0x0184e635, value(cc=0x32,in=0x08,id=0x01)--poll list has 3 items
2016-03-02 11:23:57.784 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2016-03-02 11:23:57.784 Info, contrlr,     Node 001 - Known
2016-03-02 11:23:57.784 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.784 Detail, Node001, QueryStage_CacheLoad
2016-03-02 11:23:57.784 Info, Node001, Node Identity Codes: 0086:0002:0001
2016-03-02 11:23:57.784 Detail, Node001, QueryStage_Associations
2016-03-02 11:23:57.784 Detail, Node001, QueryStage_Neighbors
2016-03-02 11:23:57.784 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2016-03-02 11:23:57.787 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2016-03-02 11:23:57.787 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2016-03-02 11:23:57.787 Info, contrlr,     Node 002 - Known
2016-03-02 11:23:57.788 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.788 Detail, Node002, QueryStage_CacheLoad
2016-03-02 11:23:57.788 Info, Node002, Node Identity Codes: 010f:0400:100a
2016-03-02 11:23:57.788 Info, Node002, NoOperation::Set - Routing=true
2016-03-02 11:23:57.788 Detail, Node002, Queuing (NoOp) NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x55, 0x95
2016-03-02 11:23:57.788 Detail, Node002, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.788 Info, contrlr,     Node 003 - Known
2016-03-02 11:23:57.788 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.788 Detail, Node003, QueryStage_CacheLoad
2016-03-02 11:23:57.788 Info, Node003, Node Identity Codes: 010f:0600:1000
2016-03-02 11:23:57.789 Info, Node003, NoOperation::Set - Routing=true
2016-03-02 11:23:57.789 Detail, Node003, Queuing (NoOp) NoOperation_Set (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x00, 0x00, 0x25, 0x56, 0x97
2016-03-02 11:23:57.789 Detail, Node003, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.789 Info, contrlr,     Node 005 - Known
2016-03-02 11:23:57.789 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.789 Detail, Node005, QueryStage_CacheLoad
2016-03-02 11:23:57.789 Info, Node005, Node Identity Codes: 015f:3102:0204
2016-03-02 11:23:57.789 Info, Node005, NoOperation::Set - Routing=true
2016-03-02 11:23:57.789 Detail, Node005, Queuing (NoOp) NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x57, 0x90
2016-03-02 11:23:57.790 Detail, Node005, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.790 Info, contrlr,     Node 006 - Known
2016-03-02 11:23:57.790 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.790 Detail, Node006, QueryStage_CacheLoad
2016-03-02 11:23:57.790 Info, Node006, Node Identity Codes: 010f:0c00:1000
2016-03-02 11:23:57.790 Info, Node006, NoOperation::Set - Routing=true
2016-03-02 11:23:57.790 Detail, Node006, Queuing (NoOp) NoOperation_Set (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x00, 0x00, 0x25, 0x58, 0x9c
2016-03-02 11:23:57.790 Detail, Node006, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.790 Info, contrlr,     Node 007 - Known
2016-03-02 11:23:57.790 Detail, Node007, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.791 Detail, Node007, QueryStage_CacheLoad
2016-03-02 11:23:57.791 Info, Node007, Node Identity Codes: 010f:0c00:1000
2016-03-02 11:23:57.791 Info, Node007, NoOperation::Set - Routing=true
2016-03-02 11:23:57.791 Detail, Node007, Queuing (NoOp) NoOperation_Set (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x00, 0x00, 0x25, 0x59, 0x9c
2016-03-02 11:23:57.791 Detail, Node007, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.791 Info, contrlr,     Node 008 - Known
2016-03-02 11:23:57.791 Detail, Node008, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.791 Detail, Node008, QueryStage_CacheLoad
2016-03-02 11:23:57.791 Info, Node008, Node Identity Codes: 010f:0800:1001
2016-03-02 11:23:57.792 Info, Node008, NoOperation::Set - Routing=true
2016-03-02 11:23:57.792 Detail, Node008, Queuing (NoOp) NoOperation_Set (Node=8): 0x01, 0x09, 0x00, 0x13, 0x08, 0x02, 0x00, 0x00, 0x25, 0x5a, 0x90
2016-03-02 11:23:57.792 Detail, Node008, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.792 Info, contrlr,     Node 009 - Known
2016-03-02 11:23:57.792 Detail, Node009, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.792 Detail, Node009, QueryStage_CacheLoad
2016-03-02 11:23:57.792 Info, Node009, Node Identity Codes: 0099:0002:0002
2016-03-02 11:23:57.792 Info, Node009, NoOperation::Set - Routing=true
2016-03-02 11:23:57.792 Detail, Node009, Queuing (NoOp) NoOperation_Set (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x00, 0x00, 0x25, 0x5b, 0x90
2016-03-02 11:23:57.793 Detail, Node009, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.793 Info, contrlr,     Node 010 - Known
2016-03-02 11:23:57.793 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.793 Detail, Node010, QueryStage_CacheLoad
2016-03-02 11:23:57.793 Info, Node010, Node Identity Codes: 010f:0202:1002
2016-03-02 11:23:57.793 Info, Node010, NoOperation::Set - Routing=true
2016-03-02 11:23:57.793 Detail, Node010, Queuing (NoOp) NoOperation_Set (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x00, 0x00, 0x25, 0x5c, 0x94
2016-03-02 11:23:57.793 Detail, Node010, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.793 Info, contrlr,     Node 011 - Known
2016-03-02 11:23:57.793 Detail, Node011, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.794 Detail, Node011, QueryStage_CacheLoad
2016-03-02 11:23:57.794 Info, Node011, Node Identity Codes: 010f:0102:1000
2016-03-02 11:23:57.794 Info, Node011, NoOperation::Set - Routing=true
2016-03-02 11:23:57.794 Detail, Node011, Queuing (NoOp) NoOperation_Set (Node=11): 0x01, 0x09, 0x00, 0x13, 0x0b, 0x02, 0x00, 0x00, 0x25, 0x5d, 0x94
2016-03-02 11:23:57.794 Detail, Node011, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.794 Info, contrlr,     Node 012 - Known
2016-03-02 11:23:57.794 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-03-02 11:23:57.794 Detail, Node012, QueryStage_CacheLoad
2016-03-02 11:23:57.794 Info, Node012, Node Identity Codes: 010f:0800:1001
2016-03-02 11:23:57.795 Info, Node012, NoOperation::Set - Routing=true
2016-03-02 11:23:57.795 Detail, Node012, Queuing (NoOp) NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x5e, 0x90
2016-03-02 11:23:57.795 Detail, Node012, Queuing (Query) Query Stage Complete (CacheLoad)
2016-03-02 11:23:57.795 Detail, Node008,   Expected reply was received
2016-03-02 11:23:57.795 Detail, Node008,   Message transaction complete
2016-03-02 11:23:57.795 Detail, contrlr, Removing current message
2016-03-02 11:23:57.796 Detail, Node001, Notification: DriverReady
2016-03-02 11:23:57.796 Detail, Node001, Notification: NodeAdded
2016-03-02 11:23:57.797 Detail, Node001, Notification: NodeProtocolInfo
2016-03-02 11:23:57.797 Detail, Node001, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.797 Detail, Node001, Notification: ValueAdded
2016-03-02 11:23:57.797 Detail, Node001, Notification: NodeNaming
2016-03-02 11:23:57.797 Detail, Node002, Notification: NodeAdded
2016-03-02 11:23:57.798 Detail, Node002, Notification: NodeProtocolInfo
2016-03-02 11:23:57.798 Detail, Node002, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.798 Detail, Node002, Notification: ValueAdded
2016-03-02 11:23:57.799 Detail, Node002, Notification: ValueAdded
2016-03-02 11:23:57.800 Detail, Node002, Notification: ValueAdded
2016-03-02 11:23:57.801 Detail, Node002, Notification: ValueAdded
2016-03-02 11:23:57.802 Detail, Node002, Notification: ValueAdded
2016-03-02 11:23:57.802 Detail, Node002, Notification: Group
2016-03-02 11:23:57.803 Detail, Node002, Notification: Group
2016-03-02 11:23:57.803 Detail, Node002, Notification: ValueAdded
2016-03-02 11:23:57.803 Detail, Node002, Notification: NodeNaming
2016-03-02 11:23:57.804 Detail, Node003, Notification: NodeAdded
2016-03-02 11:23:57.804 Detail, Node003, Notification: NodeProtocolInfo
2016-03-02 11:23:57.804 Detail, Node003, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.804 Detail, Node003, Notification: ValueAdded
2016-03-02 11:23:57.805 Detail, Node003, Notification: ValueAdded
2016-03-02 11:23:57.806 Detail, Node003, Notification: ValueAdded
2016-03-02 11:23:57.807 Detail, Node003, Notification: ValueAdded
2016-03-02 11:23:57.808 Detail, Node003, Notification: ValueAdded
2016-03-02 11:23:57.809 Detail, Node003, Notification: ValueAdded
2016-03-02 11:23:57.809 Detail, Node003, Notification: Group
2016-03-02 11:23:57.810 Detail, Node003, Notification: Group
2016-03-02 11:23:57.810 Detail, Node003, Notification: ValueAdded
2016-03-02 11:23:57.810 Detail, Node003, Notification: NodeNaming
2016-03-02 11:23:57.810 Detail, Node005, Notification: NodeAdded
2016-03-02 11:23:57.811 Detail, Node005, Notification: NodeProtocolInfo
2016-03-02 11:23:57.811 Detail, Node005, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.811 Detail, Node005, Notification: ValueAdded
2016-03-02 11:23:57.812 Detail, Node005, Notification: ValueAdded
2016-03-02 11:23:57.813 Detail, Node005, Notification: ValueAdded
2016-03-02 11:23:57.814 Detail, Node005, Notification: ValueAdded
2016-03-02 11:23:57.814 Detail, Node005, Notification: Group
2016-03-02 11:23:57.815 Detail, Node005, Notification: Group
2016-03-02 11:23:57.815 Detail, Node005, Notification: ValueAdded
2016-03-02 11:23:57.816 Detail, Node005, Notification: NodeNaming
2016-03-02 11:23:57.816 Detail, Node006, Notification: NodeAdded
2016-03-02 11:23:57.816 Detail, Node006, Notification: NodeProtocolInfo
2016-03-02 11:23:57.816 Detail, Node006, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.817 Detail, Node006, Notification: ValueAdded
2016-03-02 11:23:57.818 Detail, Node006, Notification: ValueAdded
2016-03-02 11:23:57.819 Detail, Node006, Notification: ValueAdded
2016-03-02 11:23:57.820 Detail, Node006, Notification: ValueAdded
2016-03-02 11:23:57.820 Detail, Node006, Notification: Group
2016-03-02 11:23:57.821 Detail, Node006, Notification: Group
2016-03-02 11:23:57.821 Detail, Node006, Notification: ValueAdded
2016-03-02 11:23:57.822 Detail, Node006, Notification: Group
2016-03-02 11:23:57.822 Detail, Node006, Notification: ValueAdded
2016-03-02 11:23:57.823 Detail, Node006, Notification: ValueAdded
2016-03-02 11:23:57.824 Detail, Node006, Notification: NodeNaming
2016-03-02 11:23:57.824 Detail, Node007, Notification: NodeAdded
2016-03-02 11:23:57.825 Detail, Node007, Notification: NodeProtocolInfo
2016-03-02 11:23:57.825 Detail, Node007, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.825 Detail, Node007, Notification: ValueAdded
2016-03-02 11:23:57.830 Detail, Node007, Notification: ValueAdded
2016-03-02 11:23:57.830 Detail, Node007, Notification: Group
2016-03-02 11:23:57.831 Detail, Node007, Notification: ValueAdded
2016-03-02 11:23:57.832 Detail, Node007, Notification: ValueAdded
2016-03-02 11:23:57.832 Detail, Node007, Notification: NodeNaming
2016-03-02 11:23:57.832 Detail, Node008, Notification: NodeAdded
2016-03-02 11:23:57.833 Detail, Node008, Notification: NodeProtocolInfo
2016-03-02 11:23:57.833 Detail, Node008, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.833 Detail, Node008, Notification: ValueAdded
2016-03-02 11:23:57.834 Detail, Node008, Notification: ValueAdded
2016-03-02 11:23:57.835 Detail, Node008, Notification: ValueAdded
2016-03-02 11:23:57.837 Detail, Node008, Notification: ValueAdded
2016-03-02 11:23:57.838 Detail, Node008, Notification: ValueAdded
2016-03-02 11:23:57.838 Detail, Node008, Notification: Group
2016-03-02 11:23:57.839 Detail, Node008, Notification: Group
2016-03-02 11:23:57.839 Detail, Node008, Notification: ValueAdded
2016-03-02 11:23:57.839 Detail, Node008, Notification: NodeNaming
2016-03-02 11:23:57.840 Detail, Node009, Notification: NodeAdded
2016-03-02 11:23:57.840 Detail, Node009, Notification: NodeProtocolInfo
2016-03-02 11:23:57.840 Detail, Node009, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.840 Detail, Node009, Notification: ValueAdded
2016-03-02 11:23:57.841 Detail, Node009, Notification: ValueAdded
2016-03-02 11:23:57.842 Detail, Node009, Notification: ValueAdded
2016-03-02 11:23:57.844 Detail, Node009, Notification: ValueAdded
2016-03-02 11:23:57.844 Detail, Node009, Notification: NodeNaming
2016-03-02 11:23:57.844 Detail, Node010, Notification: NodeAdded
2016-03-02 11:23:57.844 Detail, Node010, Notification: NodeProtocolInfo
2016-03-02 11:23:57.845 Detail, Node010, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.845 Detail, Node010, Notification: ValueAdded
2016-03-02 11:23:57.846 Detail, Node010, Notification: ValueAdded
2016-03-02 11:23:57.848 Detail, Node010, Notification: ValueAdded
2016-03-02 11:23:57.849 Detail, Node010, Notification: ValueAdded
2016-03-02 11:23:57.849 Detail, Node010, Notification: Group
2016-03-02 11:23:57.850 Detail, Node010, Notification: Group
2016-03-02 11:23:57.850 Detail, Node010, Notification: ValueAdded
2016-03-02 11:23:57.850 Detail, Node010, Notification: NodeNaming
2016-03-02 11:23:57.851 Detail, Node011, Notification: NodeAdded
2016-03-02 11:23:57.851 Detail, Node011, Notification: NodeProtocolInfo
2016-03-02 11:23:57.851 Detail, Node011, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.851 Detail, Node011, Notification: ValueAdded
2016-03-02 11:23:57.852 Detail, Node011, Notification: ValueAdded
2016-03-02 11:23:57.853 Detail, Node011, Notification: ValueAdded
2016-03-02 11:23:57.854 Detail, Node011, Notification: ValueAdded
2016-03-02 11:23:57.870 Detail, Node011, Notification: ValueAdded
2016-03-02 11:23:57.870 Detail, Node011, Notification: Group
2016-03-02 11:23:57.871 Detail, Node011, Notification: Group
2016-03-02 11:23:57.871 Detail, Node011, Notification: ValueAdded
2016-03-02 11:23:57.871 Detail, Node011, Notification: NodeNaming
2016-03-02 11:23:57.871 Detail, Node012, Notification: NodeAdded
2016-03-02 11:23:57.872 Detail, Node012, Notification: NodeProtocolInfo
2016-03-02 11:23:57.872 Detail, Node012, Notification: EssentialNodeQueriesComplete
2016-03-02 11:23:57.872 Detail, Node012, Notification: ValueAdded
2016-03-02 11:23:57.873 Detail, Node012, Notification: ValueAdded
2016-03-02 11:23:57.877 Detail, Node012, Notification: ValueAdded
2016-03-02 11:23:57.878 Detail, Node012, Notification: Group
2016-03-02 11:23:57.878 Detail, Node012, Notification: ValueAdded
2016-03-02 11:23:57.879 Detail, Node012, Notification: NodeNaming
2016-03-02 11:23:57.879 Detail, Node009, Notification: PollingEnabled
2016-03-02 11:23:57.880 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2016-03-02 11:23:57.882 Detail, contrlr,   Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2016-03-02 11:23:57.882 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2016-03-02 11:23:57.882 Detail, Node015,   Expected reply was received
2016-03-02 11:23:57.882 Detail, Node015,   Message transaction complete
2016-03-02 11:23:57.883 Detail, contrlr, Removing current message
2016-03-02 11:23:57.883 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2016-03-02 11:23:57.884 Detail, contrlr, Removing current message
2016-03-02 11:23:57.885 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2016-03-02 11:23:57.890 Detail, Node001,   Received: 0x01, 0x20, 0x01, 0x80, 0x16, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x4f
2016-03-02 11:23:57.891 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2016-03-02 11:23:57.891 Info, Node001,     Neighbors of this node are:
2016-03-02 11:23:57.891 Info, Node001,     Node 2
2016-03-02 11:23:57.891 Info, Node001,     Node 3
2016-03-02 11:23:57.891 Info, Node001,     Node 5
2016-03-02 11:23:57.891 Info, Node001,     Node 9
2016-03-02 11:23:57.891 Info, Node001,     Node 10
2016-03-02 11:23:57.891 Info, Node001,     Node 11
2016-03-02 11:23:57.891 Detail, Node007,   Expected reply was received
2016-03-02 11:23:57.891 Detail, Node007,   Message transaction complete
2016-03-02 11:23:57.892 Detail, Node001, Removing current message
2016-03-02 11:23:57.892 Info, Node002, Sending (NoOp) message (Callback ID=0x55, Expected Reply=0x13) - NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x55, 0x95
2016-03-02 11:23:57.897 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:23:57.898 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:23:57.910 Detail, Node002,   Received: 0x01, 0x05, 0x00, 0x13, 0x55, 0x00, 0xbc
2016-03-02 11:23:57.910 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x55 received (expected 0x55)
2016-03-02 11:23:57.910 Info, Node002, Request RTT 17 Average Request RTT 17
2016-03-02 11:23:57.910 Detail,   Expected callbackId was received
2016-03-02 11:23:57.910 Detail,   Expected reply was received
2016-03-02 11:23:57.910 Detail,   Message transaction complete
2016-03-02 11:23:57.911 Detail, Node002, Removing current message
2016-03-02 11:23:57.911 Detail, Node002, Notification: Notification - NoOperation
2016-03-02 11:23:57.911 Info, Node003, Sending (NoOp) message (Callback ID=0x56, Expected Reply=0x13) - NoOperation_Set (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x00, 0x00, 0x25, 0x56, 0x97
2016-03-02 11:23:57.916 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:23:57.917 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:23:57.929 Detail, Node003,   Received: 0x01, 0x05, 0x00, 0x13, 0x56, 0x00, 0xbf
2016-03-02 11:23:57.929 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x56 received (expected 0x56)
2016-03-02 11:23:57.929 Info, Node003, Request RTT 17 Average Request RTT 17
2016-03-02 11:23:57.929 Detail,   Expected callbackId was received
2016-03-02 11:23:57.929 Detail,   Expected reply was received
2016-03-02 11:23:57.929 Detail,   Message transaction complete
2016-03-02 11:23:57.930 Detail, Node003, Removing current message
2016-03-02 11:23:57.930 Detail, Node003, Notification: Notification - NoOperation
2016-03-02 11:23:57.930 Info, Node005, Sending (NoOp) message (Callback ID=0x57, Expected Reply=0x13) - NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x57, 0x90
2016-03-02 11:23:57.935 Detail, Node005,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:23:57.936 Detail, Node005,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:23:57.948 Detail, Node005,   Received: 0x01, 0x05, 0x00, 0x13, 0x57, 0x00, 0xbe
2016-03-02 11:23:57.948 Detail, Node005,   ZW_SEND_DATA Request with callback ID 0x57 received (expected 0x57)
2016-03-02 11:23:57.948 Info, Node005, Request RTT 17 Average Request RTT 17
2016-03-02 11:23:57.948 Detail,   Expected callbackId was received
2016-03-02 11:23:57.948 Detail,   Expected reply was received
2016-03-02 11:23:57.948 Detail,   Message transaction complete
2016-03-02 11:23:57.949 Detail, Node005, Removing current message
2016-03-02 11:23:57.949 Detail, Node005, Notification: Notification - NoOperation
2016-03-02 11:23:57.949 Info, Node006, Sending (NoOp) message (Callback ID=0x58, Expected Reply=0x13) - NoOperation_Set (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x00, 0x00, 0x25, 0x58, 0x9c
2016-03-02 11:23:57.976 Detail, Node006,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:23:57.976 Detail, Node006,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:24:02.958 Detail, Node006,   Received: 0x01, 0x05, 0x00, 0x13, 0x58, 0x01, 0xb0
2016-03-02 11:24:02.958 Detail, Node006,   ZW_SEND_DATA Request with callback ID 0x58 received (expected 0x58)
2016-03-02 11:24:02.959 Info, Node006, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-03-02 11:24:02.959 Info, Node006,   Node 6 has been marked as asleep
2016-03-02 11:24:02.959 Info, Node006, Node not responding - moving controller command to Wake-Up queue: Delete All Return Routes
2016-03-02 11:24:02.959 Info, Node006, Node not responding - moving controller command to Wake-Up queue: Assign Return Route
2016-03-02 11:24:02.959 Info, Node006, Node not responding - moving QueryStageComplete command to Wake-Up queue
2016-03-02 11:24:02.959 Detail, Node006, Notification: Notification - NoOperation
2016-03-02 11:24:02.959 Detail, Node006, Notification: Notification - Node Asleep
2016-03-02 11:24:02.960 Detail,
2016-03-02 11:24:02.960 Info, Node007, Sending (NoOp) message (Callback ID=0x59, Expected Reply=0x13) - NoOperation_Set (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x00, 0x00, 0x25, 0x59, 0x9c
2016-03-02 11:24:02.986 Detail, Node007,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:24:02.987 Detail, Node007,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:24:05.855 Detail, Node001, AdvanceQueries queryPending=1 queryRetries=0 queryStage=Neighbors live=1
2016-03-02 11:24:07.559 Detail, Node007,   Received: 0x01, 0x05, 0x00, 0x13, 0x59, 0x01, 0xb1
2016-03-02 11:24:07.559 Detail, Node007,   ZW_SEND_DATA Request with callback ID 0x59 received (expected 0x59)
2016-03-02 11:24:07.559 Info, Node007, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-03-02 11:24:07.559 Info, Node007,   Node 7 has been marked as asleep
2016-03-02 11:24:07.559 Info, Node007, Node not responding - moving controller command to Wake-Up queue: Delete All Return Routes
2016-03-02 11:24:07.560 Info, Node007, Node not responding - moving controller command to Wake-Up queue: Assign Return Route
2016-03-02 11:24:07.560 Info, Node007, Node not responding - moving QueryStageComplete command to Wake-Up queue
2016-03-02 11:24:07.560 Detail, Node007, Notification: Notification - NoOperation
2016-03-02 11:24:07.560 Detail, Node007, Notification: Notification - Node Asleep
2016-03-02 11:24:07.560 Info, Node008, Sending (NoOp) message (Callback ID=0x5a, Expected Reply=0x13) - NoOperation_Set (Node=8): 0x01, 0x09, 0x00, 0x13, 0x08, 0x02, 0x00, 0x00, 0x25, 0x5a, 0x90
2016-03-02 11:24:07.587 Detail, Node008,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:24:07.587 Detail, Node008,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:24:12.229 Detail, Node008,   Received: 0x01, 0x05, 0x00, 0x13, 0x5a, 0x01, 0xb2
2016-03-02 11:24:12.230 Detail, Node008,   ZW_SEND_DATA Request with callback ID 0x5a received (expected 0x5a)
2016-03-02 11:24:12.230 Info, Node008, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-03-02 11:24:12.230 Info, Node008,   Node 8 has been marked as asleep
2016-03-02 11:24:12.230 Info, Node008, Node not responding - moving controller command to Wake-Up queue: Delete All Return Routes
2016-03-02 11:24:12.230 Info, Node008, Node not responding - moving controller command to Wake-Up queue: Assign Return Route
2016-03-02 11:24:12.230 Info, Node008, Node not responding - moving QueryStageComplete command to Wake-Up queue
2016-03-02 11:24:12.230 Detail, Node008, Notification: Notification - NoOperation
2016-03-02 11:24:12.230 Detail, Node008, Notification: Notification - Node Asleep
2016-03-02 11:24:12.231 Detail,
2016-03-02 11:24:12.231 Info, Node009, Sending (NoOp) message (Callback ID=0x5b, Expected Reply=0x13) - NoOperation_Set (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x00, 0x00, 0x25, 0x5b, 0x90
2016-03-02 11:24:12.236 Detail, Node009,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:24:12.236 Detail, Node009,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:24:12.252 Detail, Node009,   Received: 0x01, 0x05, 0x00, 0x13, 0x5b, 0x00, 0xb2
2016-03-02 11:24:12.253 Detail, Node009,   ZW_SEND_DATA Request with callback ID 0x5b received (expected 0x5b)
2016-03-02 11:24:12.253 Info, Node009, Request RTT 21 Average Request RTT 21
2016-03-02 11:24:12.253 Detail,   Expected callbackId was received
2016-03-02 11:24:12.253 Detail,   Expected reply was received
2016-03-02 11:24:12.253 Detail,   Message transaction complete
2016-03-02 11:24:12.253 Detail, Node009, Removing current message
2016-03-02 11:24:12.253 Detail, Node009, Notification: Notification - NoOperation
2016-03-02 11:24:12.254 Info, Node010, Sending (NoOp) message (Callback ID=0x5c, Expected Reply=0x13) - NoOperation_Set (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x00, 0x00, 0x25, 0x5c, 0x94
2016-03-02 11:24:12.258 Detail, Node010,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:24:12.259 Detail, Node010,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:24:12.271 Detail, Node010,   Received: 0x01, 0x05, 0x00, 0x13, 0x5c, 0x00, 0xb5
2016-03-02 11:24:12.271 Detail, Node010,   ZW_SEND_DATA Request with callback ID 0x5c received (expected 0x5c)
2016-03-02 11:24:12.271 Info, Node010, Request RTT 17 Average Request RTT 17
2016-03-02 11:24:12.271 Detail,   Expected callbackId was received
2016-03-02 11:24:12.271 Detail,   Expected reply was received
2016-03-02 11:24:12.271 Detail,   Message transaction complete
2016-03-02 11:24:12.272 Detail, Node010, Removing current message
2016-03-02 11:24:12.272 Detail, Node010, Notification: Notification - NoOperation
2016-03-02 11:24:12.272 Info, Node011, Sending (NoOp) message (Callback ID=0x5d, Expected Reply=0x13) - NoOperation_Set (Node=11): 0x01, 0x09, 0x00, 0x13, 0x0b, 0x02, 0x00, 0x00, 0x25, 0x5d, 0x94
2016-03-02 11:24:12.277 Detail, Node011,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:24:12.278 Detail, Node011,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:24:12.293 Detail, Node011,   Received: 0x01, 0x05, 0x00, 0x13, 0x5d, 0x00, 0xb4
2016-03-02 11:24:12.293 Detail, Node011,   ZW_SEND_DATA Request with callback ID 0x5d received (expected 0x5d)
2016-03-02 11:24:12.293 Info, Node011, Request RTT 21 Average Request RTT 21
2016-03-02 11:24:12.293 Detail,   Expected callbackId was received
2016-03-02 11:24:12.294 Detail,   Expected reply was received
2016-03-02 11:24:12.294 Detail,   Message transaction complete
2016-03-02 11:24:12.294 Detail, Node011, Removing current message
2016-03-02 11:24:12.294 Detail, Node011, Notification: Notification - NoOperation
2016-03-02 11:24:12.294 Info, Node012, Sending (NoOp) message (Callback ID=0x5e, Expected Reply=0x13) - NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x5e, 0x90
2016-03-02 11:24:12.321 Detail, Node012,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-03-02 11:24:12.321 Detail, Node012,   ZW_SEND_DATA delivered to Z-Wave stack
2016-03-02 11:24:17.280 Detail, Node012,   Received: 0x01, 0x05, 0x00, 0x13, 0x5e, 0x01, 0xb6
2016-03-02 11:24:17.280 Detail, Node012,   ZW_SEND_DATA Request with callback ID 0x5e received (expected 0x5e)
2016-03-02 11:24:17.280 Info, Node012, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-03-02 11:24:17.280 Info, Node012,   Node 12 has been marked as asleep
2016-03-02 11:24:17.280 Info, Node012, Node not responding - moving controller command to Wake-Up queue: Delete All Return Routes
2016-03-02 11:24:17.281 Info, Node012, Node not responding - moving controller command to Wake-Up queue: Assign Return Route
2016-03-02 11:24:17.281 Info, Node012, Node not responding - moving QueryStageComplete command to Wake-Up queue
2016-03-02 11:24:17.281 Detail, Node012, Notification: Notification - NoOperation
2016-03-02 11:24:17.281 Detail, Node012, Notification: Notification - Node Asleep
2016-03-02 11:24:17.281 Info, Deleting all return routes from node 2
2016-03-02 11:24:17.281 Detail, Node002, Queuing (Command) ControllerCommand_DeleteAllReturnRoutess (Node=2): 0x01, 0x05, 0x00, 0x47, 0x02, 0x5f, 0xe0
2016-03-02 11:24:17.281 Detail, Notification: ControllerComand - Starting
2016-03-02 11:24:17.282 Detail,
2016-03-02 11:24:17.282 Info, Node002, Sending (Command) message (Callback ID=0x5f, Expected Reply=0x47) - ControllerCommand_DeleteAllReturnRoutess (Node=2): 0x01, 0x05, 0x00, 0x47, 0x02, 0x5f, 0xe0
2016-03-02 11:24:17.287 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x47, 0x01, 0xbc
2016-03-02 11:24:17.287 Info, Node002, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE - command in progress
2016-03-02 11:24:17.287 Detail, Notification: ControllerCommand - InProgress
2016-03-02 11:24:17.564 Detail, Node002,   Received: 0x01, 0x05, 0x00, 0x47, 0x5f, 0x00, 0xe2
2016-03-02 11:24:17.564 Info, Node002, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE for node 2 - SUCCESS
2016-03-02 11:24:17.564 Detail,   Expected callbackId was received
2016-03-02 11:24:17.564 Detail,   Expected reply was received
2016-03-02 11:24:17.564 Detail,   Message transaction complete
2016-03-02 11:24:17.565 Detail, Node002, Removing current message
2016-03-02 11:24:17.565 Detail, Notification: ControllerCommand - Completed
2016-03-02 11:24:17.565 Info, Assigning return route from node 2 to node 1
2016-03-02 11:24:17.565 Detail, Node002, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=2): 0x01, 0x06, 0x00, 0x46, 0x02, 0x01, 0x60, 0xdc
2016-03-02 11:24:17.565 Detail, Notification: ControllerComand - Starting
2016-03-02 11:24:17.566 Info, Node002, Sending (Command) message (Callback ID=0x60, Expected Reply=0x46) - ControllerCommand_AssignReturnRoute (Node=2): 0x01, 0x06, 0x00, 0x46, 0x02, 0x01, 0x60, 0xdc
2016-03-02 11:24:17.574 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x46, 0x01, 0xbd
2016-03-02 11:24:17.574 Info, Node002, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE - command in progress
2016-03-02 11:24:17.574 Detail, Notification: ControllerCommand - InProgress
2016-03-02 11:24:17.757 Detail, Node002,   Received: 0x01, 0x05, 0x00, 0x46, 0x60, 0x00, 0xdc
2016-03-02 11:24:17.758 Info, Node002, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE for node 2 - SUCCESS
2016-03-02 11:24:17.758 Detail,   Expected callbackId was received
2016-03-02 11:24:17.758 Detail,   Expected reply was received
2016-03-02 11:24:17.758 Detail,   Message transaction complete
2016-03-02 11:24:17.758 Detail, Node002, Removing current message
2016-03-02 11:24:17.758 Detail, Notification: ControllerCommand - Completed
2016-03-02 11:24:17.758 Info, Deleting all return routes from node 3
2016-03-02 11:24:17.759 Detail, Node003, Queuing (Command) ControllerCommand_DeleteAllReturnRoutess (Node=3): 0x01, 0x05, 0x00, 0x47, 0x03, 0x61, 0xdf
2016-03-02 11:24:17.759 Detail, Notification: ControllerComand - Starting
2016-03-02 11:24:17.759 Info, Node003, Sending (Command) message (Callback ID=0x61, Expected Reply=0x47) - ControllerCommand_DeleteAllReturnRoutess (Node=3): 0x01, 0x05, 0x00, 0x47, 0x03, 0x61, 0xdf
2016-03-02 11:24:17.764 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x47, 0x01, 0xbc
2016-03-02 11:24:17.764 Info, Node003, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE - command in progress
2016-03-02 11:24:17.764 Detail, Notification: ControllerCommand - InProgress
2016-03-02 11:24:17.912 Detail, Node003,   Received: 0x01, 0x05, 0x00, 0x47, 0x61, 0x00, 0xdc
2016-03-02 11:24:17.912 Info, Node003, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE for node 3 - SUCCESS
2016-03-02 11:24:17.912 Detail,   Expected callbackId was received
2016-03-02 11:24:17.913 Detail,   Expected reply was received
2016-03-02 11:24:17.913 Detail,   Message transaction complete
2016-03-02 11:24:17.913 Detail, Node003, Removing current message
2016-03-02 11:24:17.913 Detail, Notification: ControllerCommand - Completed
2016-03-02 11:24:17.913 Info, Assigning return route from node 3 to node 1
2016-03-02 11:24:17.913 Detail, Node003, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=3): 0x01, 0x06, 0x00, 0x46, 0x03, 0x01, 0x62, 0xdf
2016-03-02 11:24:17.913 Detail, Notification: ControllerComand - Starting
2016-03-02 11:24:17.914 Detail,
2016-03-02 11:24:17.914 Info, Node003, Sending (Command) message (Callback ID=0x62, Expected Reply=0x46) - ControllerCommand_AssignReturnRoute (Node=3): 0x01, 0x06, 0x00, 0x46, 0x03, 0x01, 0x62, 0xdf
2016-03-02 11:24:17.922 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x46, 0x01, 0xbd
2016-03-02 11:24:17.922 Info, Node003, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE - command in progress
2016-03-02 11:24:17.922 Detail, Notification: ControllerCommand - InProgress
2016-03-02 11:24:18.106 Detail, Node003,   Received: 0x01, 0x05, 0x00, 0x46, 0x62, 0x00, 0xde
2016-03-02 11:24:18.106 Info, Node003, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE for node 3 - SUCCESS
2016-03-02 11:24:18.106 Detail,   Expected callbackId was received
2016-03-02 11:24:18.106 Detail,   Expected reply was received
2016-03-02 11:24:18.106 Detail,   Message transaction complete
2016-03-02 11:24:18.106 Detail, Node003, Removing current message
2016-03-02 11:24:18.106 Detail, Notification: ControllerCommand - Completed
2016-03-02 11:24:18.107 Info, Deleting all return routes from node 5
2016-03-02 11:24:18.107 Detail, Node005, Queuing (Command) ControllerCommand_DeleteAllReturnRoutess (Node=5): 0x01, 0x05, 0x00, 0x47, 0x05, 0x63, 0xdb
2016-03-02 11:24:18.107 Detail, Notification: ControllerComand - Starting
2016-03-02 11:24:18.107 Info, Node005, Sending (Command) message (Callback ID=0x63, Expected Reply=0x47) - ControllerCommand_DeleteAllReturnRoutess (Node=5): 0x01, 0x05, 0x00, 0x47, 0x05, 0x63, 0xdb
2016-03-02 11:24:18.112 Detail, Node005,   Received: 0x01, 0x04, 0x01, 0x47, 0x01, 0xbc
2016-03-02 11:24:18.113 Info, Node005, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE - command in progress
2016-03-02 11:24:18.113 Detail, Notification: ControllerCommand - InProgress
2016-03-02 11:24:18.172 Detail, Node005,   Received: 0x01, 0x05, 0x00, 0x47, 0x63, 0x00, 0xde
2016-03-02 11:24:18.173 Detail,
2016-03-02 11:24:18.173 Info, Node005, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE for node 5 - SUCCESS
2016-03-02 11:24:18.173 Detail,   Expected callbackId was received
2016-03-02 11:24:18.173 Detail,   Expected reply was received
2016-03-02 11:24:18.173 Detail,   Message transaction complete
2016-03-02 11:24:18.173 Detail, Node005, Removing current message
2016-03-02 11:24:18.173 Detail, Notification: ControllerCommand - Completed
2016-03-02 11:24:18.174 Info, Assigning return route from node 5 to node 1
2016-03-02 11:24:18.174 Detail, Node005, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=5): 0x01, 0x06, 0x00, 0x46, 0x05, 0x01, 0x64, 0xdf
2016-03-02 11:24:18.174 Detail, Notification: ControllerComand - Starting
2016-03-02 11:24:18.174 Info, Node005, Sending (Command) message (Callback ID=0x64, Expected Reply=0x46) - ControllerCommand_AssignReturnRoute (Node=5): 0x01, 0x06, 0x00, 0x46, 0x05, 0x01, 0x64, 0xdf
2016-03-02 11:24:18.182 Detail, Node005,   Received: 0x01, 0x04, 0x01, 0x46, 0x01, 0xbd
2016-03-02 11:24:18.182 Info, Node005, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE - command in progress
2016-03-02 11:24:18.183 Detail, Notification: ControllerCommand - InProgress
2016-03-02 11:24:18.349 Detail, Node005,   Received: 0x01, 0x05, 0x00, 0x46, 0x64, 0x00, 0xd8
2016-03-02 11:24:18.350 Info, Node005, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE for node 5 - SUCCESS
2016-03-02 11:24:18.350 Detail,   Expected callbackId was received
2016-03-02 11:24:18.350 Detail,   Expected reply was received
2016-03-02 11:24:18.350 Detail,   Message transaction complete
2016-03-02 11:24:18.350 Detail, Node005, Removing current message
2016-03-02 11:24:18.350 Detail, Notification: ControllerCommand - Completed
Many thanks!
Freemann
Domoticz version: >=Béta
Re: No status report from Mcohome MH-S314 Four-load
Post by Freemann »
Any news on this topic? Planning to buy 2 of these modules, but only if the work properly.
Thanx guys!
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
Pietoesnoe
Freemann wrote: Wednesday 14 December 2016 14:37 Any news on this topic? Planning to buy 2 of these modules, but only if the work properly.
Thanx guys!
I would not recommend it. No status report and sometimes I have to reïnclude them because they lose connection.
Pietoesnoe
An update on the MCO touch panels. I found a solution for Smartthings (Samsung), maybe it can be used for Domoticz as wel?
https://community.smartthings.com/t/how ... home/37710
red59
Post by red59 »
Hi, i have a MH-S312 with domoticz v4.9701 (latest stable) and exactly the same problem, no status report to controller.
i have tried to add controller with all association groups without success.
does someone succeed in getting this device report its status to domoticz ?
thanks for your help
