Lua : how to read and update a text device?
Westcott
Post by Westcott »
I've got a Dummy device of Sensor type 'Text'
Unlike all my other devices, it does not respond to any Lua commands -
otherdevices[<text sensor>] returns nil
otherdevices[<text_sensor_idx>] returns nil
otherdevices_idx[<text sensor>] returns 0
commandArray[<text sensor>] = 'abc' is ignored
commandArray[<text_ensor_idx>] = 'abc' is ignored
Does anyone know how to use these devices with Lua?
simonrg
Domoticz version: 3.8807
Re: Lua : how to read and update a text device?
Post by simonrg »
otherdevices_svalue['device] retrieves the value
commandArray['UpdateDevice'] = idxoftext..'|0|'..'New Text' set the text
-- script_device_text.lua
print('TextTest '..otherdevices_svalues['TextTest'])
ttidx = otherdevices_idx['TextTest']
print('TextTest idx '..ttidx)
newtext = 'Something New'
commandArray['UpdateDevice'] = ttidx..'|0|'..newtext
--commandArray['Study'] = 'Set Level 100'
Westcott
Post by Westcott »
SimonRG thanks!
It seems that my real problem was that this new device had somehow not made it into the event system after I added it.
It showed up in the GUI OK, and in a json output.
Restarting Domoticz fixed it.
manjh
Post by manjh »
The format of the update statement for the text suggests that there may be multiple strings stored in a text device:
idx|txtidx|text
for instant:
1250|0|text
But whichever txtidx I use, the text is always stored in the device in the same way.
So is there a way to store multiple text strings in one single text device?
Hans
manjh
Post by manjh »
manjh wrote: Saturday 25 November 2017 17:56 The format of the update statement for the text suggests that there may be multiple strings stored in a text device:
idx|txtidx|text
for instant:
1250|0|text
Anyone???
Hans
Nautilus
Post by Nautilus »
Seems you've had a small misunderstanding here. The format refers to the general "UpdateDevice" syntax:
To modify an otherdevice value, you should use commandArray['UpdateDevice']='idx|nValue|sValue' where idx is the device index, nValue and sValue the values to modify (see json page for details - Domoticz API/JSON URL's)
(https://www.domoticz.com/wiki/Events)
For text sensors nValue is always 0 and sValue holds the string to be updated. And idx is of course the sensors to be updated (the unique idx of the sensor). With that said, nothing is stopping you to combine multiple strings to the same text device, you just need to include them all in the "sValue" part of the syntax. You can even use basic html formatting (and if I remember correctly, in latest beta it also respects \n for newline etc.) to have a nice link or something else in the web gui...:)
manjh
Post by manjh »
Nautilus wrote: Tuesday 28 November 2017 22:33 Seems you've had a small misunderstanding here. The format refers to the general "UpdateDevice" syntax:
OK, clear. Only one string per text device. Do you know the max length of that string?
Hans
Nautilus
Post by Nautilus »
I am able to use quite long strings (e.g. google map link to a specific location with additional address text), but there's been some issues I guess: viewtopic.php?t=18822
dannybloe
Post by dannybloe »
Why don't you use dzVents? Does it all for you and a lot easier.
