[Solved] Watchdog not started after reboot (Rasbian jessie)
wijbet
Domoticz version: Newest
Post by wijbet »
Programming my Pi with Rasbian jessie I installed watchdog.
After installing and checking I make a reboot and rechec but watchdog didn't come up.
Searching on the web, this solution works for me: https://raspberrypi.stackexchange.com/q ... rt-at-boot
Hope this wil help others.
edit [solved], typo
Pi2 + HDD, MySensors GW with some sensors and actuators (growing... )
markmichael
Re: [Solved] Watchdog not started after reboot (Rasbian jessie)
Post by markmichael »
Make sure that you have installed the software https://www.risenest.com/product-category/watchdog correctly, if not please installed it correctly.
So. here is the solution of your problem
Pull in two fixes from upstream debian 5.15 release which resolves the service starting issue.
Note, users upgrading will need to run:
systemctl enable watchdog
after upgrading to ensure watchdog service is enabled (new installers of the package will have the service enabled by default).
If still you are facing problem, then please contact an expert https://www.risezone.com/virus-support/
