not sure where to post this. Hardware? Software?
I have blinds, controlled by a KlikAanKlikUit SUN-650 controller (the old version with address wheels). Have tried several ways to add this to my Domoticz server page, but no luck.
Can someone give me a hint?
I use RFLink to generate the RF signals.
Hans
blinds with SUN-650 switch
manjh
- Domoticz version: 2025.2
Re: blinds with SUN-650 switch
I think I found the reason why it doesn't work, although the problem is not solved.
The blinds switch is programmed for address B16. When I monitor what RFLink sends out, it is B10!
I tried other addresses, all are find from B1 through B15. But B16 is not sent out correctly...
Is it sufficient to report that here, or should I move this post elsewhere?
Hans
Hans
Hans
