Philips Hue choice status update when switched outside of Domoticz Topic is solved
tozzke
Domoticz version: Stable
Post by tozzke »
I know this might be a bit of a strange request because most of us (including me) waited a long time for the status of Hue bulbs being dealt with correctly within Domoticz when switched with an other app or a Livingwhites remote control. It seems that since a recent update it's the case that the event system will trigger on changes of the Hue bulbs when switched ouside of Domoticz which is (in some cases) great! ;)
But now my issue... I kind of got used to the fact Domoticz wouldn't trigger events when I switched my bulbs externally. I used it quite frequently to "overrule" the bulbs/events and now this isn't possible anymore, the events just retrigger which making overruling impossible. :cry:
Is there a possibility to add an option @ the Hue Bridge hardware within Domoticz whether you'd want the event system to update the bulb's status correctly when switched externally or not.
gizmocuz
Re: Philips Hue choice status update when switched outside of Domoticz
Post by gizmocuz »
That will break all logic
Can't you rebuild your event scripts ?
tozzke
Post by tozzke »
so this:
should become this?
gizmocuz
Post by gizmocuz »
it that works.... sure why not ?
