I run several different Domoticz instances with the RaspberryPis I have. However when they are running, it's not easy to distinguish between the different types. What I do at the moment is edit the index.html in the www directory and edit the <title> "...."</title> every time the Domoticz software is updated.
My thoughts are can we define a variable in domoticz.sh that is used for the title bar instead? Although the obvious problem is domoticz.sh might get overwritten each time too!
Just a thought for this wonderful software.....
Andy
Define Title Of Current Domoticz Instance?
AndyWhittaker
Andy Whittaker
Macclesfield, UK
Blog-> http://blog.ecufix.com/
http://www.andywhittaker.com/
http://www.ecufix.com/
Macclesfield, UK
stlaha2007
- Target OS: -
Re: Define Title Of Current Domoticz Instance?
I would vote +1. Something based on hostname or fqdn when using full dns inhouse very appriciated.
However as a current workaround:
Im using ThinkPads Theme. In his custom.css around line 300 theres is a line with "content: 'ThinkThrme by ThinkPad'. I have modified this to include my name to identify my slightly modified version of his Theme.
I'm not sure every theme has that line but will give you the option for the moment, just copy your used theme and modify it to your likings and select that theme.
Grtz,
Stephan
Grtz,
Stephan
asjmcguire
- Domoticz version: 3.5877
What if instead of a variable in domoticz.sh it was a uservariable that the domoticz javascript would check exists and change the title dynamically once the page is loaded?
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
