433Mhz USB Alternative?
Posted: Thursday 25 February 2016 11:52
by Thies
Hi Guys,
I was looking into a cheaper alternative then the RFXCOM (100 euro's), this would make it even more main stream. I found the following USB adapter, is this compatible or can we make it compatible? What are you ideas about this?
http://www.alibaba.com/product-detail/U ... .70.zub0To
Best,
Thijs
Re: 433Mhz USB Alternative?
Posted: Thursday 25 February 2016 12:05
by Stuntteam
Nope, that will not work as it is using GFSK modulation while most of the signals are ASK.
Did you check out the RFLink? You can build that for a few euros and it supports a lot of protocols.
All you need is an Arduino Mega and a decent RF receiver & transmitter..
You could score the hardware for ~10 euros already.. or spend a bit more if you order locally
More info: http://www.nemcon.nl/blog2/
Posted: Thursday 25 February 2016 12:18
by Derik
RF link................
