Combination of a Dummy switch + text device
Holland
Domoticz version: Beta Ch
Post by Holland »
Just wondering if there is already something available where I can show a dynamic text within a switch button.
Quite similar to the mediaplayer button used for Kodi. If a movie is playing the button also shows the title of the movie
thanks
pluggin
Re: Combination of a Dummy switch + text device
Post by pluggin »
I use a dummy TEXT sensor and with a script change the svalue. The only problem is don´t log the info over time
dec=$data
curl -s "http://192.168.0.8:9550/json.htm?type=c ... value=$dec" > /dev/null
Is this what you looking for?
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
Holland
Post by Holland »
That is one of things I'm trying to achieve. The text (the above variable dec) should display on a switch icon
See the below media button I use for Kodi.
pluggin
Post by pluggin »
Yes, the $dec variable, the contains the value you want to display in the text sensor
Holland
Post by Holland »
But with just a textsensor I can't switch anything.
The above image is a switch, but with the functionality of a text sensor integrated. The circled part is dynamic.
hendrik6073
Post by hendrik6073 »
how do you handle white spaces in text ? if i add white spaces text is not displayed. i can work around it by placing dots and underscores, text is not clearly readeble with all those dots and underscores. Also would like to use the \n newline character to ge info clear and readable in ImperiHome buttons
Yann
Post by Yann »
For the white space, insert %20 instead and it will work.
HP Microserver + Domoticz + Aeon Labs Z-Wave USB +RFX433
ronnyandre
Post by ronnyandre »
Is this something that is possible in current version of Domoticz?
Newbie just started with Domoticz and home automation.
