Personalised scenes buttons Topic is solved
bxlouis
Domoticz version: 2020.1
Post by bxlouis »
I grouped all my blinds in a scene so that I have to turn the scene "On" to close and "off" to open them all.
Is it possible to personnalize the scene so that it looks like a blind switch ?
Then I would be able to set them open/close instead of on/off!
Thank you for your help!
StanHD
Re: Personalised scenes buttons
Post by StanHD »
Afaik it isn't possible to change the Group / Scene switch Icons, however as a "work around":-
You could make a Virtual Blinds switch then switch the group (scene) on and off using the JSON interface in the switch On Action & Off Action fields:-
From the Wiki:-
http://<username:password@>domoticz-ip<:port>/json.htm?type=command&param=switchscene&idx=&switchcmd=
idx = id of your scene/group.
switchcmd = "On" or "Off" (case sensitive!)
Scenes can only be turned On
I think it should work.
Python:- Broadlink RM2, Sonos
