This blockly works, but not allways
Evelen
Domoticz version: 2.4538
Post by Evelen »
What the blockly is doing:
- If I open one of my two closets and the light in the room is turned off, the light should be turned on (to white with dim level 100%)
- When the both closets are closed again the light should turn off.
- If the light in the room is on before I open any off the closets nothins should happen.
This is the problem:
- Somtimes the light don't turn off after I close the doors. Especially if I open it quickly and then close it again
Any suggestions on how I can fix this?
