Cron usage
Number8
Domoticz version: 2022.1
Cron usage
Post by Number8 »
I'm not very familiar with Cron. I set it up with the following instruction, expecting to have the script run every minutes. But it does not work.
*/1 * * * * /home/domoticz/scripts/script.sh
The script works fine when launched at the command line level
Owner of the script is pi.
Thank you
Debian buster on NUC and three RPi with buster.
alfred_j_kwak
Domoticz version: 2.3530
Re: Cron usage
Post by alfred_j_kwak »
Have you tried Google? "Cron once a minute" give me correct answer in first link.
Number8
Re: Cron usage
Post by Number8 »
I did Google before posting. I did try without success this entry as well
* * * * * /home/domoticz/scripts/script.sh
Number8
Re: Cron usage
Post by Number8 »
It did not work bercause the script did not have the execution property set
alfred_j_kwak
Re: Cron usage
But cron in your first post was also incorrect?
Just want to make sure that when someone else is searching help he/she will get correct information.
Number8
Re: Cron usage
Post by Number8 »
indeed, but before posting I had try the one that works. The issue the execution not set
Egregius
Domoticz version: v2024.7
Re: Cron usage
Post by Egregius »
In my opinion */1 is the same as *
Altough there's no purpose of specifying */1 to run every minute as * is the same. */2 on the other hand runs every 2 minutes.
alfred_j_kwak
Re: Cron usage
Egregius - you are right in both of your arguments. I have to admit that I have never even tried to use */1 cause * does the trick.
