zwave-temp-sensor for £10?
Posted: Thursday 11 February 2016 16:54
by kman
Hi, looking for a zwave temp sensor for £10.
Most zwave devices like fibaro, aeon ..etc are all in the range of £30 or higher.
Any ideas or suggestions will be much appreciated.
Many thanks,
-krish
Re: zwave-temp-sensor for £10?
Posted: Thursday 11 February 2016 17:00
by Evelen
impossible, go for 443 MHz sensors on temperature
Posted: Thursday 11 February 2016 17:05
by kman
Can you please provide me with more info 443 MHz sensors. I am new to all of this. Many thanks!
Posted: Thursday 11 February 2016 17:14
by mischa
@Kman on this website you will find all the information for mysensors
http://www.mysensors.org/
Posted: Thursday 11 February 2016 17:28
by kman
Also, if am using 433 MHz sensors, how do I integrate that with Domoticz? is there another library like openzwave which could be used?
Posted: Thursday 11 February 2016 19:01
by Evelen
kman wrote:Also, if am using 433 MHz sensors, how do I integrate that with Domoticz? is there another library like openzwave which could be used?
You need one of these:
http://www.rfxcom.com/store/Transceivers/14103
All devices will come under "Devices",
Stuff that works with it:
https://www.domoticz.com/wiki/Hardware
I use this:
http://www.ebay.com/itm/261788376051
Posted: Friday 12 February 2016 15:31
by kman
@Evelen - thanks for the info.
I had a few additional questions...
I am planning to use RPi with "RFXtrx433E USB 433.92MHz Transceiver"
If I already have domoticz installed on RPi then, all that is required to be done from Linux per se is to install "Mono" and use it to run RFXflash.exe program when I need to upgrade the firmware on RFXtrx433E? Do I need to upgrade the firmware on RFXtrx433E when I receive it?
Aside from that is it safe to assume that once I have RPi connected(usb) to RFXtrx433E with Domoticz running on RPi, there is no additional sw installation required on RPi?
How does one enable/disable protocols on RFXtrx433E - is that done via domoticz?
Many thanks.
Posted: Friday 12 February 2016 15:53
by manwe
If you use switches or dimmers from qubino you can connect an temperature sensor in this price range to the switch.
The big advantage is that it is powered. I hate to change (and pay) batteries
Cheap(£10) temp/Humidity sensor - for RFXtrx433E
Posted: Saturday 13 February 2016 20:03
by kman
I found Cresta TX-320 - but it doesn't seem to be available in the UK and shipment costs from Netherlands is around euro 19.
Any suggestions on cheap Temp/Humidity sensor under £10 - compatible with RFXtrx433E/Domoticz?
