combine 2 switches inside one on/off
jeje77
Domoticz version: 2.4031
Post by jeje77 »
Hello, :roll:
My electrical outlet needs to have 2 switches on my domoticz ... one to turn it on and one to turn it off ... :shock:
I would like if possible to combine this 2 switches inside one on/off ;)
I already try to create a script but for the way I found, my 2 switches have to stay where they are :cry:
=> I suggest (I think) that it can be good to have the possibility to combine the switches together.
thanks
stlaha2007
Re: combine 2 switches inside one on/off
Post by stlaha2007 »
Hi jeje77,
I think your half way...
One switch (domoticz way) can hold two different scripts (eventualy even one with parameter on or off if you like).
Another way, what comes to mind is the following. Domoticz devices can be hidden by naming them with a dollarsign as first character in there name.
So create new switch(or group) and call so to speak the hidden switch to turn it on and the other as off action.
I hope you understand what i mean and hopefully make you smile when that works :-)
Grtz,
Stephan
jeje77
Post by jeje77 »
Thanks Stephan :D
Your second way work 8-)
Thanks for the tips "$" ..... that change everything ;)
tonse
Domoticz version: 3.8771
Post by tonse »
How can i "call" a hidden switch?
stlaha2007
Simple answer do a json call according to wiki as a script action.
i dont use hidden devices at the moment. All my devices are normally represented or triggering on/off action scripts.
Grtz,
Stephan
jannl
Domoticz version: 2025.5.x
Post by jannl »
You also can a an http json call to the on- and off action of a virtual switch, in this way you do not need to create a script
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
Maybe you can use the new selector switch for this.
