Hello
Anyone knows if Domoticz (v2.4460) is working with the Netatmo wind gauge please or this has not been implemented yet?
Alex
Netatmo wind gauge
mvzut
Re: Netatmo wind gauge
I have the Netatmo wind sensor, and it works fine on all version of Domoticz that I have used since I bought it. This includes the latest stable version and a number of beta versions. Two remarks:
- The resolution is a bit worse than with the 433 MHz wind meter I had before (I believe the resolution is just below 1 m/s)
- It reports a windchill temperature, but that is always zero. Probably because it doesn't have an internal temperature sensor, in contrast to most 433 MHz wind meters
Francis
Hello
I am a new guy of Domoticz use on Raspberry pi. I refer mvzut' post told the Domoticz worked with Netatmo Wind gauge. I would like to got more information.
Does the Domoticz need the Netatmo Weather station as a bridge to talk with the Netatmo Wind gauge, or talk with the Wind gauge directly. And what hardware request need ? how about the setup on the Domoticz ?
Best Regards
Francis
Best Regards
Francis
Francis
Hello, can you provide more information on how to talk with the Netatmo Wind Gauge ? I cannot found any useful information, except the window gauge operate in 868 /915MHz.mvzut wrote:I have the Netatmo wind sensor, and it works fine on all version of Domoticz that I have used since I bought it. This includes the latest stable version and a number of beta versions. Two remarks:
Thakns in advance.
Br
Francis
