How to see if script is running?
Evelen
Domoticz version: 2.4538
Post by Evelen »
Hi, just got my MiLights up, and wanted to try this script: http://www.domoticz.com/forum/viewtopic.php?f=23&t=3402
So i saved the script in home/flemmingss/domoticz/script/wake_me_up_light.sh on the server (ubuntu server).
Also installed Netcat
Than I made a dummy switsh named "start wake_me_up_light.sh" with on-action:
script://home/flemmingss/domoticz/scripts/wake_me_up_light.sh
but nothing happening if i start it.
How can I see if scripts is running?
(So i can see if the problem is the script, og if it is that the script is not started).
Never started scripts before, just used blockly.
Logg:
2016-02-05 22:40:45.277 User: flemmingss initiated a switch command
2016-02-05 22:40:45.277 (Dummy) Lighting 2 (start wake_me_up_light.sh)
Egregius
Domoticz version: v2024.7
Re: How to see if script is running?
Post by Egregius »
You could add a echo line to the script.
replace
function verzend(){
  echo -n -e $SENDCOM | nc -u -q 1 $IP $PORT
  sleep $RUNTIME
with
function verzend(){
  echo $(date +"%Y-%m-%d %H:%M:%S") : $SENDCOM >> /var/log/script.log
  sleep $RUNTIME
Evelen
Post by Evelen »
same result.
also no script.log in var/log/ :(
Egregius
Post by Egregius »
I now see that you only have 2 // instead of 3
2 // = relative to domoticz scripts folders
3 /// = absolute path
script:///home/flemmingss/domoticz/scripts/wake_me_up_light.sh
Also, I believe it should be in the domoticz logfile. Something like executing script /home/flemmingss/domoticz/scripts/wake_me_up_light.sh
Is the script executable for the user domoticz runs?
Evelen
Post by Evelen »
Now I got this:
2016-02-05 23:56:56.125 User: flemmingss initiated a switch command
2016-02-05 23:56:56.125 (Dummy) Lighting 2 (start wake_me_up_light.sh)
2016-02-05 23:56:56.360 Executing script: /home/flemmingss/domoticz/scripts/wake_me_up_light.sh
2016-02-05 23:56:56.362 Error: Error executing script command (/home/flemmingss/domoticz/scripts/wake_me_up_light.sh). returned: 32256
"Is the script executable for the user domoticz runs?"
I don't know, how do i check?
Egregius
Post by Egregius »
ls -l /home/flemmingss/domoticz/scripts/wake_me_up_light.sh
should have x in the output:
-rwxr--r-- 1 pi pi 464 Jan 17 22:51 wake_me_up_light.sh
x = executable
if not:
chmod +x wake_me_up_light.sh
https://www.google.be/?gws_rd=ssl#q=mak ... able+linux
oliviers
Domoticz version: Stable
Post by oliviers »
This looks like a long-running script. Domoticz doesn't like that. Scripts should be as quick as possible.
The way to go: Write two scripts:
The first one, which you will assign to "action on", will execute quickly (as to avoid disturbing Domoticz), and will just launch the second script, in background, with all your other commands, delays, etc:
The (very simple) first script will look like:
#!/bin/bash
/home/pi/domotics/scripts/wake_me_up_light.sh &  <== Please note the "&" (ampersand) which will ensure that 'wake_me_up_light.sh ' is launched in background, thus allowing this script to proceed and complete without waiting
Hope this helps,
Oliviers
Paris area
Raspberry Pi 4 - RFXComm 433 - IrTrans - Zwave
Evelen
Post by Evelen »
Egregius wrote:ls -l /home/flemmingss/domoticz/scripts/wake_me_up_light.sh
x = executable
if not:
oliviers : Is this a script O make to start the orginal script?
Egregius
Post by Egregius »
the script isn't executable. Run this command:
chmod +x /home/flemmingss/domoticz/scripts/wake_me_up_light.sh
But, as Oliviers said, place another script in between.
Something like /home/flemmings/domoticz/scripts/wake_me_up_light_exe.sh
with this content:
#!/bin/bash
Then put script:///home/flemmings/domoticz/scripts/wake_me_up_light_exe.sh in the action of the switch.
With this script in between, domoticz can continue instantly because the _exe script starts the real script in the background.
