Problem: RFXCOM partially lost receiving ability
Posted: Friday 05 February 2016 9:58
couple days ago i have got red temperature sensors (temp_sensors.png). I use Oregon sensors and Digimax thermostats in my project, both used Oregon protocol to communicate with RFXCOM. I think i have got some problems with RFXCOM receiver, and reboot my
Odroid. Nothing happens, temperature sensors was lost. I thikk my RFXCOM is died, and replace it with spare one. Just the same situation. I replace my power source for Odroid - just the same. In the lig-file i can see:
2016-02-05 08:34:21.392 RFXCOM: Using serial port: /dev/ttyUSB21
subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 194
Hardware version = 1.1
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU enabled
Meiantech/Atlantic disabled
what means (in my mind
that RFXCOM is alive. Moreover, i can send X10 commands via it to manage my heaters.
2016-02-05 08:39:29.783 (RfxTrx Interface) Lighting 1 (Heater: Corridor)
2016-02-05 08:39:30.194 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:31.916 User: Admin initiated a switch command
2016-02-05 08:39:31.923 (RfxTrx Interface) Lighting 1 (Heater: Corridor)
2016-02-05 08:39:32.230 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:38.784 User: Admin initiated a switch command
2016-02-05 08:39:38.784 (RfxTrx Interface) Lighting 1 (Heater: Diningroom)
2016-02-05 08:39:39.247 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:41.150 User: Admin initiated a switch command
2016-02-05 08:39:41.157 (RfxTrx Interface) Lighting 1 (Heater: Diningroom)
2016-02-05 08:39:41.302 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:45.412 User: Admin initiated a switch command
2016-02-05 08:39:45.419 (RfxTrx Interface) Lighting 1 (Heater: Hall)
2016-02-05 08:39:46.324 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:51.687 User: Admin initiated a switch command
2016-02-05 08:39:51.694 (RfxTrx Interface) Lighting 1 (Heater: Hall)
2016-02-05 08:39:52.112 User: Admin initiated a switch command
2016-02-05 08:39:52.118 (RfxTrx Interface) Lighting 1 (Heater: Hall)
2016-02-05 08:39:52.383 Executing script: /home/pi/domoticz/scripts/domoticz_m
In addition, just one sensor of 12 still work:
2016-02-05 11:27:58.149 (RfxTrx Interface) Temp + Humidity (TempSensor: Bathro
and it is really alive (work_sensor.png)/ Шежы not most closest sensor to RFXCOM, i don't know why it still work.
Summing, i have lost ability to receive temerature sensors info via RFXCOM (exept one sensor (???)) via Oregon protocol and
OWL sensors info. In the same time, i can send X10 commands via the same RFXCOM.
I use Odriod-C1 as "head of system" and Domoticz v2.4389 (was 2.4111, same effect). I try to replace power supplies,
main units (i mean Odroid device), RFXCOM devices (old one, fw v.194 and new one, fw v.250), reflash fw on old one... Right now all my house
conrol completely unusable in automatic mode. Could someone help?
Sequence nbr = 2
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU enabled
