Problem: RFXCOM partially lost receiving ability
eagapov
Domoticz version: Stable
Post by eagapov »
couple days ago i have got red temperature sensors (temp_sensors.png). I use Oregon sensors and Digimax thermostats in my project, both used Oregon protocol to communicate with RFXCOM. I think i have got some problems with RFXCOM receiver, and reboot my
Odroid. Nothing happens, temperature sensors was lost. I thikk my RFXCOM is died, and replace it with spare one. Just the same situation. I replace my power source for Odroid - just the same. In the lig-file i can see:
2016-02-05 08:34:21.392 RFXCOM: Using serial port: /dev/ttyUSB21
subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 194
Hardware version = 1.1
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU enabled
Meiantech/Atlantic disabled
what means (in my mind :) that RFXCOM is alive. Moreover, i can send X10 commands via it to manage my heaters.
2016-02-05 08:39:29.783 (RfxTrx Interface) Lighting 1 (Heater: Corridor)
2016-02-05 08:39:30.194 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:31.916 User: Admin initiated a switch command
2016-02-05 08:39:31.923 (RfxTrx Interface) Lighting 1 (Heater: Corridor)
2016-02-05 08:39:32.230 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:38.784 User: Admin initiated a switch command
2016-02-05 08:39:38.784 (RfxTrx Interface) Lighting 1 (Heater: Diningroom)
2016-02-05 08:39:39.247 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:41.150 User: Admin initiated a switch command
2016-02-05 08:39:41.157 (RfxTrx Interface) Lighting 1 (Heater: Diningroom)
2016-02-05 08:39:41.302 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:45.412 User: Admin initiated a switch command
2016-02-05 08:39:45.419 (RfxTrx Interface) Lighting 1 (Heater: Hall)
2016-02-05 08:39:46.324 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:51.687 User: Admin initiated a switch command
2016-02-05 08:39:51.694 (RfxTrx Interface) Lighting 1 (Heater: Hall)
2016-02-05 08:39:52.112 User: Admin initiated a switch command
2016-02-05 08:39:52.118 (RfxTrx Interface) Lighting 1 (Heater: Hall)
2016-02-05 08:39:52.383 Executing script: /home/pi/domoticz/scripts/domoticz_m
In addition, just one sensor of 12 still work:
2016-02-05 11:27:58.149 (RfxTrx Interface) Temp + Humidity (TempSensor: Bathro
and it is really alive (work_sensor.png)/ Шежы not most closest sensor to RFXCOM, i don't know why it still work.
Summing, i have lost ability to receive temerature sensors info via RFXCOM (exept one sensor (???)) via Oregon protocol and
OWL sensors info. In the same time, i can send X10 commands via the same RFXCOM.
I use Odriod-C1 as "head of system" and Domoticz v2.4389 (was 2.4111, same effect). I try to replace power supplies,
main units (i mean Odroid device), RFXCOM devices (old one, fw v.194 and new one, fw v.250), reflash fw on old one... Right now all my house
conrol completely unusable in automatic mode. Could someone help?
jannl
Domoticz version: 2026.1.x
Re: Problem: RFXCOM partially lost receiving ability
Post by jannl »
Did you reboot the Pi already?
It happens with my RFXcom a few times last year, reboot of the pi solved it.
b_weijenberg
Post by b_weijenberg »
I suppose there is a sensor transmitting RF noise.
Do you also have X10 MS13 sensors? If so I guess there is a MS13 with low battery.
Or else remove the battery for test from the sensor that is still operating.
RFX-433, RFX-433EMC, RFX-868
eagapov
Post by eagapov »
Sure, i did reboot. From Windows world it's first action you should do :) But - all the same :(
Yes, i have 3 MS13 (мау be, MS10) in home. I will try to replace battarys, thank you. I have some suspicions about RF noice, but
who was able to produce it?
Dmesg output below:
[ 0.000000@0] Booting Linux on physical CPU 0x200
[ 0.000000@0] Initializing cgroup subsys cpuset
[ 0.000000@0] Initializing cgroup subsys cpuacct
[ 0.000000@0] Linux version 3.10.80-141 (root@xu3-b2) (gcc version 4.9.2 (Ubuntu/Linaro 4.9.2-0ubuntu1~14.04) ) #1 SMP PREEMPT Wed Jan 27 23:07:36 BRST 2016
[ 0.000000@0] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c5387d
[ 0.000000@0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000@0] Machine: ODROIDC, model: AMLOGIC
[ 0.000000@0] physical memory start address is 0x200000
[ 0.000000@0] reserved_end is e3fffff
[ 0.000000@0]
[ 0.000000@0] Total memory is 1022 MiB
[ 0.000000@0] Reserved low memory from 0x06000000 to 0x0e3fffff, size: 132 MiB
[ 0.000000@0] mesonfb0(low) : 0x06100000 - 0x07900000 ( 24 MiB)
[ 0.000000@0] mesonfb1(low) : 0x07900000 - 0x07a00000 ( 1 MiB)
[ 0.000000@0] mesonstream0(low) : 0x07a00000 - 0x09a00000 ( 32 MiB)
[ 0.000000@0] vdec0(low) : 0x09a00000 - 0x0da00000 ( 64 MiB)
[ 0.000000@0] ppmgr0(high) : 0x3f000000 - 0x40000000 ( 16 MiB)
[ 0.000000@0] amvideocap0(low) : 0x0da00000 - 0x0e400000 ( 10 MiB)
[ 0.000000@0] cma: CMA: reserved 8 MiB at 3e800000
[ 0.000000@0] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000@0] On node 0 totalpages: 220160
[ 0.000000@0] free_area_init_node: node 0, pgdat c09e9c00, node_mem_map c0c83000
[ 0.000000@0] Normal zone: 1520 pages used for memmap
[ 0.000000@0] Normal zone: 0 pages reserved
[ 0.000000@0] Normal zone: 157184 pages, LIFO batch:31
[ 0.000000@0] HighMem zone: 492 pages used for memmap
[ 0.000000@0] HighMem zone: 62976 pages, LIFO batch:15
[ 0.000000@0] Meson chip version = RevA (1B:A - 0:B72)
[ 0.000000@0] PERCPU: Embedded 8 pages/cpu @c146c000 s8256 r8192 d16320 u32768
[ 0.000000@0] pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096
[ 0.000000@0] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 218640
[ 0.000000@0] Kernel command line: root=UUID=e139ce78-9841-40fe-8823-96a304a09859 rootwait ro console=tty0 console=ttyS0,115200n8 no_console_suspend vdaccfg=0xa000 logo=osd1,loaded,0x7900000,720p,full dmfc=3 cvbsmode=576cvbs hdmimode=1080p m_bpp=32 vout=hdmi disableuhs disablehpd=true
[ 0.000000@0] cvbs trimming line = 0xa000
[ 0.000000@0] cvbs trimming.1.v5: 0xa0, 0x0
[ 0.000000@0] osd1:1
[ 0.000000@0] loaded:268435459
[ 0.000000@0] logo has been loaded
[ 0.000000@0] 720p:11
[ 0.000000@0] full:2
[ 0.000000@0] kernel get cvbsmode form uboot is 576cvbs
[ 0.000000@0] kernel get hdmimode form uboot is 1080p
[ 0.000000@0] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000@0] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000@0] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000@0] allocated 2060288 bytes of page_cgroup
[ 0.000000@0] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000@0] Memory: 64MB 16MB 780MB = 860MB total
[ 0.000000@0] Memory: 845192k/845192k available, 35448k reserved, 243712K highmem
[ 0.000000@0] Virtual kernel memory layout:
[ 0.000000@0] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000@0] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000@0] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000@0] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000@0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000@0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000@0] .text : 0xc0008000 - 0xc0937cfc (9408 kB)
[ 0.000000@0] .init : 0xc0938000 - 0xc0970040 ( 225 kB)
[ 0.000000@0] .data : 0xc0972000 - 0xc09eab40 ( 483 kB)
[ 0.000000@0] .bss : 0xc09eab40 - 0xc0c7e6fc (2639 kB)
[ 0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000@0] Preemptible hierarchical RCU implementation.
[ 0.000000@0] NR_IRQS:256
[ 0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000@0] Global timer: MESON TIMER-F (c098d400) initialized
[ 0.000000@0] Switching to timer-based delay loop
[ 0.000000@0] Console: colour dummy device 80x30
[ 0.000000@0] console [tty0] enabled
[ 0.000000@0] meson_serial_console_setup
[ 0.000000@0] console [ttyS0] enabled
[ 0.347576@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.357849@0] pid_max: default: 32768 minimum: 301
[ 0.362829@0] Security Framework initialized
[ 0.366889@0] AppArmor: AppArmor initialized
[ 0.371217@0] Mount-cache hash table entries: 512
[ 0.379945@0] Initializing cgroup subsys memory
[ 0.380399@0] Initializing cgroup subsys devices
[ 0.384871@0] Initializing cgroup subsys freezer
[ 0.389451@0] Initializing cgroup subsys blkio
[ 0.393912@0] Initializing cgroup subsys perf_event
[ 0.398862@0] CPU: Testing write buffer coherency: ok
[ 0.404194@0] CPU0: thread -1, cpu 0, socket 2, mpidr 80000200
[ 0.409626@0] Setting up static identity map for 0xc0693e40 - 0xc0693e98
[ 0.416390@0] L310 cache controller enabled
[ 0.420414@0] l2x0: 8 ways, 2048 sets, CACHE_ID 0x4100a0c9, Cache size: 524288 B
[ 0.427811@0] AUX_CTRL 0x7ec60001, PERFETCH_CTRL 0x75000007, POWER_CTRL 0x00000000
[ 0.435961@0] TAG_LATENCY 0x00000111, DATA_LATENCY 0x00000222
[ 0.520321@1] CPU1: Booted secondary processor
[ 0.520340@1] CPU1: thread -1, cpu 1, socket 2, mpidr 80000201
[ 0.540319@2] CPU2: Booted secondary processor
[ 0.540337@2] CPU2: thread -1, cpu 2, socket 2, mpidr 80000202
[ 0.560318@3] CPU3: Booted secondary processor
[ 0.560335@3] CPU3: thread -1, cpu 3, socket 2, mpidr 80000203
[ 0.560425@0] Brought up 4 CPUs
[ 0.588613@0] SMP: Total of 4 processors activated (8.00 BogoMIPS).
[ 0.594845@0] CPU: All CPU(s) started in SVC mode.
[ 0.600347@0] devtmpfs: initialized
[ 0.609553@0] clkrate [ xtal ] : 24000000
[ 0.609599@0] clkrate [ pll_sys ] : 1200000000
[ 0.612554@0] clkrate [ pll_fixed ] : 2550000000
[ 0.617206@0] clkrate [ pll_vid ] : 732000000
[ 0.621633@0] clkrate [ pll_ddr ] : 0
[ 0.625344@0] clkrate [ a9_clk ] : 1200000000
[ 0.629760@0] clkrate [ clk81 ] : 159375000
[ 0.634385@0] pinctrl core: initialized pinctrl subsystem
[ 0.639583@0] regulator-dummy: no parameters
[ 0.644130@0] NET: Registered protocol family 16
[ 0.652358@0] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.656364@0] VPU driver version: v02
[ 0.658942@0] load vpu_clk in dts: 182150000Hz(3)
[ 0.663670@0] vpu_probe OK
[ 0.668189@0] amlogic_gpio gpio: Probed amlogic GPIO driver
[ 0.672252@0] register lm device lm-root
[ 0.675771@0] register lm device lm1
[ 0.679317@0] register lm device lm0
[ 0.682922@0] hw-breakpoint: found 2 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.691001@0] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.697048@0] Init pinux probe!
[ 0.700751@0] pinmux-m8b pinmux: Probed amlogic pinctrl driver
[ 0.705906@0] tv_init_module
[ 0.708732@0] major number 254 for disp
[ 0.712554@0] vout_register_server
[ 0.715914@0] register tv module server ok
[ 0.720058@0] hdmitx: system: amhdmitx_init
[ 0.724141@0] hdmitx: system: Ver: 2014May6
[ 0.728358@0] hdmitx: system: amhdmitx_probe
[ 0.732833@0] hdmitx: system: gate/pwr cmd: 7
[ 0.736872@0] hdmitx: system: ALREADY init VIC = 4
[ 0.741649@0] hdmitx: system: gate/pwr cmd: 0
[ 0.746387@1] hdmitx: system: reset intr mask
[ 0.777253@0] bio: create slab <bio-0> at 0
[ 0.777949@0] SCSI subsystem initialized
[ 0.779879@0] usbcore: registered new interface driver usbfs
[ 0.785417@0] usbcore: registered new interface driver hub
[ 0.790903@0] usbcore: registered new device driver usb
[ 0.796060@0] media: Linux media interface: v0.10
[ 0.800714@0] Linux video capture interface: v2.00
[ 0.805854@0] request vpu clk holdings: vencp 159375000Hz
[ 0.810824@0] TV mode 1080p selected.
[ 0.814433@0] tvoutc_setmode[459]
[ 0.817719@0] aml_logo: outputmode changed(11->25), reset osd1 scaler.
[ 4.823324@0] Advanced Linux Sound Architecture Driver Initialized.
[ 4.824368@0] Bluetooth: Core ver 2.16
[ 4.827722@0] NET: Registered protocol family 31
[ 4.832308@0] Bluetooth: HCI device and connection manager initialized
[ 4.838781@0] Bluetooth: HCI socket layer initialized
[ 4.843812@0] Bluetooth: L2CAP socket layer initialized
[ 4.849007@0] Bluetooth: SCO socket layer initialized
[ 4.854178@0] Loading modules backported from Linux version next-20150129-0-g828f79f
[ 4.861739@0] Backport integrated by backports.git backports-20150129-0-gdd4a670
[ 4.869307@0] cfg80211: Calling CRDA to update world regulatory domain
[ 4.876214@0] Switching to clocksource Timer-E
[ 4.880334@0] AppArmor: AppArmor Filesystem Enabled
[ 4.892149@0] NET: Registered protocol family 2
[ 4.892884@0] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 4.898352@0] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 4.904964@0] TCP: Hash tables configured (established 8192 bind 8192)
[ 4.911398@0] TCP: reno registered
[ 4.914700@0] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 4.920803@0] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 4.927461@0] NET: Registered protocol family 1
[ 4.931977@0] Unpacking initramfs...
[ 5.130999@0] Freeing initrd memory: 3352K (c4e08000 - c514e000)
[ 5.131991@0] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 3 counters available
[ 5.140167@0] audit: initializing netlink socket (disabled)
[ 5.145178@0] type=2000 audit(5.040:1): initialized
[ 5.150715@0] bounce pool size: 64 pages
[ 5.158970@0] VFS: Disk quotas dquot_6.5.2
[ 5.159236@0] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 5.166477@0] aufs 3.10.x
[ 5.167240@0] msgmni has been set to 1181
[ 5.172778@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 5.178756@0] io scheduler noop registered
[ 5.182847@0] io scheduler deadline registered
[ 5.187364@0] io scheduler cfq registered (default)
[ 5.234878@0] [drm] Initialized drm 1.1.0 20060810
[ 5.235047@0] gpu cooling register okay with err=0
[ 5.241666@0] Mali: Mali device driver loaded
[ 5.243281@0] UMP: UMP device driver -jenkins-deb_kernel_c1-141 loaded
[ 5.252525@0] loop: module loaded
[ 5.253438@0] tun: Universal TUN/TAP device driver, 1.6
[ 5.258122@0] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 5.264612@0] PPP generic driver version 2.4.2
[ 5.269198@0] usbcore: registered new interface driver usb-storage
[ 5.275145@0] usbcore: registered new interface driver usbserial
[ 5.281036@0] usbcore: registered new interface driver usbserial_generic
[ 5.287673@0] usbserial: USB Serial support registered for generic
[ 5.294062@0] mousedev: PS/2 mouse device common for all mice
[ 5.299763@0] i2c /dev entries driver
[ 5.303519@0] device-mapper: uevent: version 1.0.3
[ 5.308180@0] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email protected]
[ 5.316646@0] Bluetooth: HCI UART driver ver 2.2
[ 5.321087@0] Bluetooth: HCI H4 protocol initialized
[ 5.326003@0] Bluetooth: HCI BCSP protocol initialized
[ 5.331126@0] Bluetooth: HCILL protocol initialized
[ 5.335960@0] Bluetooth: HCIATH3K protocol initialized
[ 5.341084@0] Bluetooth: HCI Three-wire UART (H5) protocol initialized
[ 5.348094@0] ledtrig-cpu: registered to indicate activity on CPUs
[ 5.353802@0] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.359493@0] usbcore: registered new interface driver usbhid
[ 5.364991@0] usbhid: USB HID core driver
[ 5.369170@0] efuse===========================================
[ 5.374918@0] efuse: device efuse created
[ 5.378783@0] efuse--------------------------------------------
[ 5.384643@0] vout_init_module
[ 5.387685@0] start init vout module
[ 5.391425@0] create vout attribute ok
[ 5.395425@0] ge2d_init
[ 5.397792@0] ge2d_dev major:244
[ 5.401235@0] ge2d start monitor
[ 5.404448@0] osd_init
[ 5.404462@1] ge2d workqueue monitor start
[ 5.410925@0] osd_probe, vinfo:c06d4258
[ 5.414975@0] Frame buffer memory assigned at phy:0x06100000, vir:0xf1000000, size=24576K
[ 5.422844@0] osd_probe, mydef_var:c09c06d0, vinfo:c06d4258
[ 5.428352@0] init fbdev bpp is :32
[ 5.431914@0] ---------------clear framebuffer0 memory
[ 6.453272@0] Console: switching to colour frame buffer device 160x90
[ 6.466459@0] Frame buffer memory assigned at phy:0x07900000, vir:0xf0600000, size=1024K
[ 6.474435@0] osd_probe, mydef_var:c09c06d0, vinfo:c06d4258
[ 6.479923@0] don't find to display_size_default from mesonfb-dts
[ 6.486005@0] init fbdev bpp is :24
[ 7.480042@0] osd probe ok
[ 7.480111@0] hdmitx: video: get current mode: 1080p
[ 7.482382@0] hdmitx: video: get current mode: 1080p
[ 7.487315@0] hdmitx: system: gate/pwr cmd: 7
[ 7.491696@0] hdmitx: system: already init VIC = 0 Now VIC = 16
[ 7.497632@0] hdmitx: system: 16 (cd0,cs0,pm1,vd0,1)
[ 7.502741@0] hdmitx: system: gate/pwr cmd: 0
[ 7.507047@0] hdmitx: system: hw reset
[ 7.511818@0] hdmitx: audio: SPDIF
[ 7.514185@0] reconfig packet setting done
[ 7.538199@0] hdmitx: system: set pll
[ 7.538271@0] hdmitx: system: param->VIC:16
[ 7.540449@0] mode is: 25
[ 7.543015@0] VPU_VIU_VENC_MUX_CTRL: 0xa
[ 7.546923@0] viu chan = 1
[ 7.549593@0] VPU_VIU_VENC_MUX_CTRL: 0xa
[ 7.553519@0] config HPLL
[ 7.570039@0] config HPLL done
[ 7.570109@0] enc_vpu_bridge_reset[314]
[ 7.710035@0] hdmitx: system: phy setting done
[ 7.710121@0] hdmi: Fixing to HDMI Mode
[ 7.712698@0] hdmi: Sink is HDMI device
[ 7.716510@0] hdmi: No sink attached
[ 7.720110@0] hdmitx: audio: audio channel num is 0
[ 7.724929@0] hdmitx: audio: SPDIF
[ 7.728287@0] hdmitx: audio: current VIC: 16
[ 7.732546@0] hdmitx: audio: audio sample rate: 0
[ 7.737213@0] hdmitx: audio: reset audio N para
[ 7.741744@0] hdmitx: audio: PCM out to HDMI
[ 7.758381@0] hdmitx: audio: Time out: AIU_HDMI_CLK_DATA_CTRL
[ 7.758556@0] hdmitx: audio: i2s_to_spdif_flag:1
[ 7.763235@0] hdmitx: audio: Enable audio spdif to HDMI
[ 7.806240@0] amlvideo-000: V4L2 device registered as video10
[ 7.806650@0] ionvideo-000: V4L2 device registered as video13
[ 7.812156@0] Video Technology Magazine Ion Video Capture Board ver 1.0 successfully loaded.
[ 7.820578@0] DI: di_init
[ 7.820675@0] aml_wdt_driver_init,306
[ 7.824152@0] ** disable watchdog
[ 7.827514@0] one-secod=7812,min_timeout=1,max_timeout=8,default_timeout=10,reset_watchdog_method=0,reset_watchdog_time=2,shutdown_timeout=10,firmware_timeout=6,suspend_timeout=6
[ 7.843721@0] AML Watchdog Timer probed done
[ 7.847925@0] set uart_ao pinmux use pinctrl subsystem
[ 7.852764@0] P_AO_RTI_PIN_MUX_REG:1801
[ 7.856557@0] start uart_ao_ttyS0:(irq = 122)
[ 7.860884@0] register uart_ao ok
[ 7.864359@0] set uart_b pinmux use pinctrl subsystem
[ 7.869188@0] P_AO_RTI_PIN_MUX_REG:1801
[ 7.876427@0] start uart_b_ttyS2:(irq = 107)
[ 7.880602@0] register uart_b ok
[ 7.884088@0] dwc_otg: version 3.10a 12-MAY-2014
[ 7.888403@0] dwc_otg lm-root: dwc_otg_driver_probe(ef343800)
[ 7.888414@0] dwc_otg_driver_probe NOT match
[ 7.892664@0] dwc_otg lm1: dwc_otg_driver_probe(ef343a00)
[ 7.932669@0] usb1: type: 1, speed: 0, config: 0, dma: 0, id: 1, phy: fe108820, ctrl: fe080000
[ 7.939153@0] USB (1) use clock source: XTAL input
[ 7.944966@0] dwc_otg lm1: base=0xfe080000
[ 7.944977@0] dwc_otg lm1: dwc_otg_device=0xef5df1c0
[ 7.965106@0] Core Release: 3.10a
[ 7.968625@0] Setting default values for core params
[ 7.972169@0] curmode: 1, host_only: 1
[ 7.975674@0] dwc_otg lm1: DMA config: BURST_DEFAULT
[ 7.995830@0] Using Buffer DMA mode
[ 7.999300@0] OTG VER PARAM: 1, OTG VER FLAG: 1
[ 8.002788@0] Working on port type = HOST
[ 8.006492@0] dwc_otg lm1: DWC OTG Controller
[ 8.009969@0] dwc_otg lm1: new USB bus registered, assigned bus number 1
[ 8.016653@0] dwc_otg lm1: irq 63, io mem 0x00000000
[ 8.021539@0] -------hcd->flags.d32 = 0
[ 8.025353@0] Init: Port Power? op_state=1
[ 8.029405@0] Init1: Power Port (0)
[ 8.033399@0] hub 1-0:1.0: USB hub found
[ 8.036907@0] hub 1-0:1.0: 1 port detected
[ 8.041052@0] dwc_otg lm0: dwc_otg_driver_probe(ef343c00)
[ 8.041088@0] usb0: type: 0, speed: 0, config: 0, dma: 0, id: 0, phy: fe108800, ctrl: fe040000
[ 8.049553@0] USB (0) use clock source: XTAL input
[ 8.055320@0] dwc_otg lm0: base=0xfe040000
[ 8.055332@0] dwc_otg lm0: dwc_otg_device=0xef5e2440
[ 8.075426@0] Core Release: 3.10a
[ 8.079000@0] Setting default values for core params
[ 8.082592@0] curmode: 1, host_only: 0
[ 8.126086@0] dwc_otg lm0: DMA config: BURST_DEFAULT
[ 8.146247@0] Using Buffer DMA mode
[ 8.149740@0] OTG VER PARAM: 1, OTG VER FLAG: 1
[ 8.153248@0] Working on port type = OTG
[ 8.156725@0] Current port type: SLAVE
[ 8.160428@0] dwc_otg lm0: DWC OTG Controller
[ 8.163997@0] dwc_otg lm0: new USB bus registered, assigned bus number 2
[ 8.170678@0] dwc_otg lm0: irq 62, io mem 0x00000000
[ 8.176002@0] hub 2-0:1.0: USB hub found
[ 8.179451@0] hub 2-0:1.0: 1 port detected
[ 8.183642@0] Dedicated Tx FIFOs mode
[ 8.187529@0] using timer detect id change, ef58a400
[ 8.192269@0] ethernet_driver probe!
[ 8.195684@0] ethernetinit(dbg[c09c52ec]=1)
[ 8.199807@0] ethernet base addr is fe0c0000
[ 8.204110@0] write mac add to:ef5e7e08: 00 1e 06 c2 b0 98 |.\x1e....|
[ 8.214630@0] libphy: AMLMAC MII Bus: probed
[ 8.218106@0] eth0: PHY ID 001cc916 at 0 IRQ -1 (0:00) active
[ 8.222464@0] eth0: PHY ID 001cc916 at 1 IRQ -1 (0:01) active
[ 8.228299@0] amvideocap_init_module
[ 8.231880@0] amvideocap_probe,amvideocap
[ 8.235673@0] amvideocap_dev_register buf:0da00000,size:a00000.
[ 8.241659@1] Indeed it is in host mode hprt0 = 00021501
[ 8.247027@0] Amlogic A/V streaming port init
[ 8.252538@0] init vdec memsource 9a00000->d9fffff
[ 8.256213@0] [tsync_pcr_init]init success.
[ 8.260321@0] regist mpeg12 codec profile
[ 8.264289@0] regist mpeg4 codec profile
[ 8.268122@0] amvdec_vc1 module init
[ 8.271725@0] regist vc1 codec profile
[ 8.275387@0] amvdec_h264 module init
[ 8.279099@0] regist h264 codec profile
[ 8.282877@0] amvdec_h265 module init
[ 8.286518@0] regist hevc codec profile
[ 8.290350@0] regist mjpeg codec profile
[ 8.294178@0] amvdec_real module init
[ 8.297863@0] regist real codec profile
[ 8.301648@0] amvdec_avs module init
[ 8.305359@0] regist avc codec profile
[ 8.308906@0] jpegenc module init
[ 8.312657@0] alloc_keep_buffer keep_y_addr ee600000
[ 8.317227@0] alloc_keep_buffer keep_u_addr eeb00000
[ 8.322088@0] alloc_keep_buffer keep_v_addr eec00000
[ 8.327004@0] yaddr=ee600000,u_addr=eeb00000,v_addr=eec00000
[ 8.332922@0] create_ge2d_work_queue video task ok
[ 8.337654@0] SARADC Driver init.
[ 8.341267@0] __saradc_probe__
[ 8.420063@1] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 8.424556@3] Indeed it is in host mode hprt0 = 00001101
[ 8.490154@0] saradc calibration: ref_val = 509
[ 8.493448@0] saradc calibration: ref_nominal = 512
[ 8.497128@0] saradc calibration: coef = 4136
[ 8.501689@0] ir irblaster probe
[ 8.505127@0] Remote Driver
[ 8.508459@0] ==touch_ts_init==
[ 8.511770@0] ==ft5x0x_ts_init==
[ 8.514982@0] ==goodix_ts_init==
[ 8.518188@0] i2c-core: driver [gslx680_compatible] using legacy suspend method
[ 8.524253@0] i2c-core: driver [gslx680_compatible] using legacy resume method
[ 8.531435@0] !!!ntp_ts: ret = 0.
[ 8.534698@0] VTL ct36x TouchScreen driver, <[email protected]>.
[ 8.541192@2] i2c-core: driver [ct36x] using legacy suspend method
[ 8.547261@2] i2c-core: driver [ct36x] using legacy resume method
[ 8.553316@2] VTL ct36x TouchScreen driver End.
[ 8.557789@2] ==gsl_ts_init==
[ 8.560970@2] ret=0
[ 8.564245@2] i2c-core: driver [mir3da] using legacy suspend method
[ 8.569078@2] i2c-core: driver [mir3da] using legacy resume method
[ 8.575251@2] i2c-core: driver [lis3dh_acc] using legacy suspend method
[ 8.581805@2] i2c-core: driver [lis3dh_acc] using legacy resume method
[ 8.588299@2] i2c-core: driver [bma222] using legacy suspend method
[ 8.594498@2] i2c-core: driver [bma222] using legacy resume method
[ 8.600693@2] i2c-core: driver [dmard06] using legacy suspend method
[ 8.606956@2] i2c-core: driver [dmard06] using legacy resume method
[ 8.613223@2] lsm303d driver: init
[ 8.616597@2] i2c-core: driver [dmard10] using legacy suspend method
[ 8.622102@3] hub 1-1:1.0: USB hub found
[ 8.622434@3] hub 1-1:1.0: 4 ports detected
[ 8.630891@2] i2c-core: driver [dmard10] using legacy resume method
[ 8.637180@2] stk8313_init
[ 8.640282@2] ======stk831x init ok======
[ 8.643802@2] stk831x_init
[ 8.646873@2] mxc622x accelerometer driver: init
[ 8.651117@2] i2c-core: driver [mxc622x] using legacy suspend method
[ 8.657442@2] i2c-core: driver [mxc622x] using legacy resume method
[ 8.663673@2] mxc6255xc accelerometer driver: init
[ 8.668438@2] i2c-core: driver [mxc6255xc] using legacy suspend method
[ 8.674951@2] i2c-core: driver [mxc6255xc] using legacy resume method
[ 8.681418@2] cm3217 v.1.0.0.1
[ 8.684549@2] i2c-core: driver [elan_epl6814] using legacy suspend method
[ 8.691193@2] i2c-core: driver [elan_epl6814] using legacy resume method
[ 8.697848@2] i2c-core: driver [LTR501] using legacy suspend method
[ 8.704073@2] i2c-core: driver [LTR501] using legacy resume method
[ 8.710341@2] mmc driver version: 1.07, 2014-06-30: eMMC add hw reset function
[ 8.718404@2] host->base fe108e00
[ 8.721700@2] pdata->caps 107
[ 8.724825@2] pdata->caps2 0
[ 8.727906@2] get property: port, value:0x00000004
[ 8.732996@2] get property: ocr_avail, value:0x00200080
[ 8.739445@2] get property: f_min, value:0x000493e0
[ 8.745956@2] get property: f_max, value:0x05f5e100
[ 8.752423@2] get property: max_req_size, value:0x00020000
[ 8.758872@2] get property: irq_in, value:0x00000003
[ 8.765355@2] get property: irq_out, value:0x00000005
[ 8.771835@2] get property: gpio_cd, str:CARD_6
[ 8.777772@2] get property: pinname, str:sd
[ 8.783395@2] get property: card_type, value:0x00000005
[ 8.789895@2] get property: gpio_dat3, str:CARD_4
[ 8.795875@2] get property: gpio_volsw, str:GPIOAO_3
[ 8.802189@2] aml_sd_voltage_switch[1309] : Switched to voltage -> 3.30 V
[ 8.860069@0] sd: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 8.899321@1] sd: new high speed SDHC card at address 59b4, clock 50000000, 4-bit-bus-width
[ 8.900375@3] usb 1-1.2: new full-speed USB device number 3 using dwc_otg
[ 8.912343@1] mmcblk0: sd:59b4 NCard 14.9 GiB
[ 8.917310@1] mmcblk0: p1 p2
[ 8.920047@2] [aml_sdhc_probe] aml_sdhc_probe() success!
[ 8.925050@2] host->base fe108c20
[ 8.928329@2] pdata->caps 80000507
[ 8.931566@2] pdata->caps2 1
[ 8.934756@2] get property: port, value:0x00000002
[ 8.940661@2] get property: ocr_avail, value:0x00200000
[ 8.947150@2] get property: f_min, value:0x000493e0
[ 8.953667@2] get property: f_max, value:0x02faf080
[ 8.960129@2] get property: f_max_w, value:0x02faf080
[ 8.966573@2] get property: max_req_size, value:0x00020000
[ 8.973072@2] get property: pinname, str:emmc
[ 8.978855@2] get property: card_type, value:0x00000001
[ 8.985347@2] get property: gpio_dat3, str:BOOT_3
[ 8.991285@2] [is_emmc_exist] host->storage_flag=0, POR_BOOT_VALUE=1
[ 9.030070@1] emmc: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 9.034385@1] aml_emmc_hw_reset 1379
[ 9.090042@2] [aml_sdio_probe] aml_sdio_probe() success!
[ 9.093369@2] [dsp]DSP start addr 0xc5e00000
[ 9.097181@2] [dsp]register dsp to char divece(257)
[ 9.103050@2] aml_rtc rtc.1: rtc core: registered aml_rtc as rtc0
[ 9.109595@2] amlogic rfkill init
[ 9.113021@2] Bluetooth: btwake_control_init Driver Ver 1.1
[ 9.117342@2] aml_hw_crypto initialization.
[ 9.122293@2] pcm5102_platform_probe
[ 9.125910@2] enter aml_i2s_dai_probe
[ 9.125920@2] i2s get no clk src setting in dts, use the default mpll 0
[ 9.131447@2] enter aml_pcm_dai_probe
[ 9.131654@2] enter spdif_dit_probe
[ 9.134929@2] aml_spdif_unmute
[ 9.139160@2] aml-i2s 0:playback preallocate_dma_buffer: area=f04fc000, addr=3ec40000, size=65536
[ 9.147199@2] aml-i2s 1:capture preallocate_dma_buffer: area=f050e000, addr=3ec60000, size=65536
[ 9.155659@2] aml_snd_m8 aml_m8_sound_card.4: dit-hifi <-> aml-spdif-dai.0 mapping ok
[ 9.164592@2] GACT probability NOT on
[ 9.168024@2] Mirror/redirect action on
[ 9.172081@2] NET: Registered protocol family 10
[ 9.176273@2] mip6: Mobile IPv6
[ 9.179719@2] sit: IPv6 over IPv4 tunneling driver
[ 9.184382@2] NET: Registered protocol family 17
[ 9.188095@2] NET: Registered protocol family 15
[ 9.192719@2] Bridge firewalling registered
[ 9.196933@2] Bluetooth: RFCOMM TTY layer initialized
[ 9.201860@2] Bluetooth: RFCOMM socket layer initialized
[ 9.207062@2] Bluetooth: RFCOMM ver 1.11
[ 9.210924@2] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.216398@2] Bluetooth: BNEP filters: protocol multicast
[ 9.221766@2] Bluetooth: BNEP socket layer initialized
[ 9.226825@2] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 9.232933@2] Bluetooth: HIDP socket layer initialized
[ 9.238034@2] NET: Registered protocol family 35
[ 9.243137@2] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[ 9.250452@2] Registering SWP/SWPB emulation handler
[ 9.255536@2] pm-meson: probe of aml_pm_m8 failed with error -1
[ 9.261783@2] registered taskstats version 1
[ 9.265588@2] regulator-dummy: disabling
[ 9.269652@2] Mali DRM initialize, driver name: mali_drm, version 2.1
[ 9.276158@2] [drm] Initialized mali_drm 2.1.1 20140306 on minor 0
[ 9.282039@2] Mali DRM initialize, driver name: mali_drm, version 2.1
[ 9.288649@2] [drm] Initialized mali_drm 2.1.1 20140306 on minor 1
[ 9.295204@2] aml_rtc rtc.1: setting system clock to 2016-02-05 05:27:46 UTC (1454650066)
[ 9.302861@2] ### dt-test ### No testcase data in device tree; not running tests
[ 9.310290@2] meson_cpufreq_probe:SYSPLL request to be fixed
[ 9.310368@3] usb 1-1.4: new low-speed USB device number 4 using dwc_otg
[ 9.322515@2] meson_cpufreq: no voltage_control prop
[ 9.327463@2] voltage_control = 0
[ 9.331918@2] <<-GTP-INFO->> GTP driver installing...
[ 9.335223@2] buf[0]=90,buf[1]=b0,err=4
[ 9.338831@2] adc=388,TS_C=16,flag=1
[ 9.342398@2] efuse_flag=a
[ 9.345267@2] amlogic_thermal_probe, this chip is trimmed, use thermal
[ 9.351629@2] amlogic-thermal aml_thermal: amlogic thermal probe start
[ 9.358134@2] #thermal-cells=7
[ 9.361162@2] pdata->temp_trip_count=4
[ 9.364891@2] temperature=70 on trip point=0
[ 9.369136@2] fixing high_freq=1488001 to 1488000 at trip point 0,level=3
[ 9.375904@2] fixing low_freq=1488001 to 1488000 at trip point 0,level=3
[ 9.382606@2] gpu[0].gpu_high_freq=511,tmp_level[0].gpu_high_freq=511
[ 9.389032@2] cpu[0] core num==3
[ 9.392216@2] gpu[0] core num==2
[ 9.395355@2] temperature=80 on trip point=1
[ 9.399567@2] fixing high_freq=1200001 to 1200000 at trip point 1,level=6
[ 9.406311@2] fixing low_freq=1200001 to 1200000 at trip point 1,level=6
[ 9.413003@2] gpu[1].gpu_high_freq=435,tmp_level[1].gpu_high_freq=435
[ 9.419440@2] cpu[1] core num==2
[ 9.422632@2] gpu[1] core num==2
[ 9.425814@2] temperature=90 on trip point=2
[ 9.430088@2] fixing high_freq=800001 to 696000 at trip point 2,level=11
[ 9.436748@2] fixing low_freq=800001 to 696000 at trip point 2,level=11
[ 9.443364@2] gpu[2].gpu_high_freq=328,tmp_level[2].gpu_high_freq=328
[ 9.449822@2] cpu[2] core num==1
[ 9.453036@2] gpu[2] core num==1
[ 9.456224@2] temperature=110 on trip point=3
[ 9.460581@2] fixing high_freq=-1 to -22 at trip point 3,level=-1
[ 9.466632@2] fixing low_freq=-1 to -22 at trip point 3,level=-1
[ 9.472632@2] gpu[3].gpu_high_freq=-1,tmp_level[3].gpu_high_freq=-1
[ 9.478906@2] cpu[3] core num==-1
[ 9.482175@2] gpu[3] core num==-1
[ 9.485413@2] idle interval=1000
[ 9.488585@2] pdata->name:aml_thermal
[ 9.492419@2] tmp_trip[0].cpu_core_upper=1
[ 9.496296@2] tmp_trip[1].cpu_core_upper=2
[ 9.500353@2] tmp_trip[2].cpu_core_upper=3
[ 9.504374@2] tmp_trip[3].cpu_core_upper=-1
[ 9.508506@2] aml_thermal bind thermal-cpucore-0 okay !
[ 9.513749@2] aml_thermal bind thermal-cpufreq-0 okay !
[ 9.518869@2] pdata->tmp_trip[0].gpu_lower_level=1
[ 9.523639@2] pdata->tmp_trip[0].gpu_upper_level=1
[ 9.528363@2] pdata->tmp_trip[1].gpu_lower_level=2
[ 9.533091@2] pdata->tmp_trip[1].gpu_upper_level=2
[ 9.537841@2] pdata->tmp_trip[2].gpu_lower_level=4
[ 9.542556@2] pdata->tmp_trip[2].gpu_upper_level=4
[ 9.547265@2] pdata->tmp_trip[3].gpu_lower_level=-1
[ 9.552068@2] pdata->tmp_trip[3].gpu_upper_level=-1
[ 9.556868@2] aml_thermal bind thermal-gpufreq-0 okay !
[ 9.562207@2] amlogic: Kernel Thermal management registered
[ 9.567621@2] amlogic-thermal aml_thermal: amlogic thermal probe done
[ 9.574106@2] hdmitx: cec: CEC init
[ 9.577586@1] hdmitx: cec: CEC task process
[ 9.577724@2] input: cec_input as /devices/virtual/input/input0
[ 9.587683@2] hdmitx: cec: hdmitx_device->cec_init_ready:0x1
[ 9.590497@2] ALSA device list:
[ 9.596309@2] #0: ODROID-HDMI
[ 9.599660@2] config uart_ao_ttyS0:: Character length 8bits/char
[ 9.610049@2] Changing uart_ao_ttyS0: baud from 0 to 115200
[ 9.630241@2] Freeing unused kernel memory: 224K (c0938000 - c0970000)
[ 10.636336@1] systemd-udevd[113]: starting version 204
[ 11.031407@3] hid-generic 0003:051D:0002.0001: hiddev0,hidraw0: USB HID v1.10 Device [American Power Conversion Back-UPS CS 350 FW:807.q5.I USB FW:q5] on usb-lm1-1.4/input0
[ 11.126475@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.129618@1] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.141114@2] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.147053@2] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.151447@2] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 11.157995@2] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.164752@2] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.174390@2] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.182691@3] tvmode set to 1080p
[ 11.182691@3]
[ 11.182713@3] don't set the same mode as current.
[ 11.201891@2] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 11.201898@2] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.201905@2] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.202559@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.202564@1] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 11.202570@1] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.202577@1] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.203338@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.203344@1] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 11.203349@1] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.203355@1] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.203976@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.203981@1] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 11.203985@1] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.203990@1] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.205061@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.205067@1] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 11.205072@1] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.205078@1] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.214161@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.214170@1] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.214176@1] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.214801@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.214807@1] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 11.214812@1] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.214818@1] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.215479@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 11.215485@1] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 11.215490@1] end_request: I/O error, dev mmcblk0, sector 31291384
[ 11.215496@1] Buffer I/O error on device mmcblk0, logical block 3911423
[ 11.456076@0] tvmode set to 1080p
[ 11.456076@0]
[ 11.456194@0] don't set the same mode as current.
[ 11.563946@3] force enable DISCARD here for ext4 fs
[ 11.569595@3] checked enable EXT4 DISCARD here
[ 11.569688@3] EXT4-fs (mmcblk0p2): mounting with "discard" option, but the device does not support discard
[ 11.578167@3] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[ 12.073342@0] config uart_ao_ttyS0:: Character length 8bits/char
[ 12.140613@2] init: plymouth-upstart-bridge main process (159) terminated with status 1
[ 12.143291@2] init: plymouth-upstart-bridge main process ended, respawning
[ 12.154558@3] config uart_ao_ttyS0:: Character length 8bits/char
[ 12.179451@1] init: plymouth-upstart-bridge main process (169) terminated with status 1
[ 12.182647@1] init: plymouth-upstart-bridge main process ended, respawning
[ 12.197871@2] config uart_ao_ttyS0:: Character length 8bits/char
[ 12.222912@0] init: plymouth-upstart-bridge main process (173) terminated with status 1
[ 12.225416@0] init: plymouth-upstart-bridge main process ended, respawning
[ 12.233583@0] init: ureadahead main process (162) terminated with status 5
[ 12.250473@0] config uart_ao_ttyS0:: Character length 8bits/char
[ 12.966956@2] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 13.017662@2] systemd-udevd[279]: starting version 204
[ 13.051133@3] emmc: mmc_rescan_try_freq: trying to init card at 300000 Hz
[ 13.090530@3] aml_emmc_hw_reset 1379
[ 13.649404@0] aml_gpio_probe : success
[ 13.656690@2] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.658112@0] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.673754@0] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.679763@0] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 13.680773@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.711137@1] Driver for 1-wire Dallas network protocol.
[ 13.768670@0] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.775060@0] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.782711@2] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 13.797707@1] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.817091@0] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.827729@2] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.834997@2] mmcblk0: r/w command failed, status = 0x80000b00
[ 13.841414@2] mmc_blk_reset 938 reset error md->reset_done:1 and type:1
[ 13.871502@0] usbcore: registered new interface driver ftdi_sio
[ 13.871577@0] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 13.871713@0] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
[ 13.871815@0] usb 1-1.2: Detected FT232RL
[ 13.871825@0] usb 1-1.2: Number of endpoints 2
[ 13.871833@0] usb 1-1.2: Endpoint 1 MaxPacketSize 64
[ 13.871841@0] usb 1-1.2: Endpoint 2 MaxPacketSize 64
[ 13.871847@0] usb 1-1.2: Setting MaxPacketSize 64
[ 13.873180@0] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 14.402093@3] ionvideo open
[ 14.402279@3] ionvideo_stop_generating!!!!
[ 14.402299@3] ionvideo release
[ 14.922059@0] netdev_open
[ 14.922071@0] Ethernet reset
[ 14.922100@0] NET MDA descpter start addr=eda00000
[ 14.988677@0] phy_interface = 0
[ 14.988692@0] aml_phy_init: trying to attach to 0:01
[ 14.988864@0] am_rtl811f called phy reset
[ 14.383342@0] amlvideo openamlvideo close
[ 15.000175@0] --1--write mac add to:ef5e7e08: 00 1e 06 c2 b0 98 |.\x1e....|
[ 15.000204@0] --2--write mac add to:ef5e7e08: 00 1e 06 c2 b0 98 |.\x1e....|
[ 15.000220@0] write mac add to:ef5e7e08: 00 1e 06 c2 b0 98 |.\x1e....|
[ 15.000237@0] Current DMA mode=0, set mode=621c100
[ 15.000266@0] eth0: opened (irq 40).
[ 15.010270@0] ether leave promiscuous mode
[ 15.010291@0] ether leave all muticast mode
[ 15.010381@0] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 19.000125@0] [adjust link] -> eth: full-duplex
[ 19.000137@0] [adjust link] -> eth: phy_speed <> priv_speed)
[ 19.000151@0] [adjust link -> eth: am_adjust_link state change (new_state=true)
[ 19.000158@0] libphy: 0:01 - Link is Up - 1000/Full
[ 19.000203@0] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 22.075484@2] init: failsafe main process (479) killed by TERM signal
[ 24.300978@3] init: plymouth-upstart-bridge main process ended, respawning
Edit: Please place logs like this in a 'Spoiler'
jannl
Post by jannl »
Did you also check the Domoticz logging?
eagapov
Post by eagapov »
Yes, of course. In logging - all OK, but completely absents any marks of receiving information from thermo-sensors (except one working).
Below - example:
it's - receiving from one working sensor (2nd line from bottom)
2016-02-05 10:44:07.377 User: Admin initiated a switch command
2016-02-05 10:44:07.378 (Presence) Lighting 1 (Big UPS Power)
2016-02-05 10:44:07.671 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 10:44:07.692 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 10:44:20.002 Hardware Monitor: Fetching data (System sensors)
2016-02-05 10:44:39.167 (Pinger) Lighting 2 (Pool Camera)
2016-02-05 10:44:39.714 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 10:44:41.087 (Weather Underground) Temp + Humidity + Baro (Weather $
2016-02-05 10:44:41.123 (Weather Underground) Wind (Weather Station: Wind)
2016-02-05 10:44:41.141 (Weather Underground) UV ($Weather Station: UV Index)
2016-02-05 10:44:41.159 (Weather Underground) Rain (Weather Station: Rain)
2016-02-05 10:44:41.177 (Weather Underground) General/Visibility ($Weather Sta$
2016-02-05 10:44:50.138 Hardware Monitor: Fetching data (System sensors)
2016-02-05 10:44:55.166 (RfxTrx Interface) Temp + Humidity (TempSensor: Bathro$
2016-02-05 10:45:06.585 EventSystem: Script event triggered: /home/pi/domoticz$
it's - X10 commands receiving (1. 4. 8 line)
2016-02-05 08:39:09.671 (RfxTrx Interface) Lighting 1 (Heater: Water Boiler)
2016-02-05 08:39:10.096 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:14.947 User: Admin initiated a switch command
2016-02-05 08:39:14.954 (RfxTrx Interface) Lighting 1 (Heater: Kitchen)
2016-02-05 08:39:15.142 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:24.380 Hardware Monitor: Fetching data (System sensors)
2016-02-05 08:39:25.668 User: Admin initiated a switch command
2016-02-05 08:39:25.675 (RfxTrx Interface) Lighting 1 (Heater: Kitchen)
2016-02-05 08:39:26.162 Executing script: /home/pi/domoticz/scripts/domoticz_m$
2016-02-05 08:39:29.777 User: Admin initiated a switch command
jannl
Post by jannl »
Are you sure you got an RFXCOM and configured it right?
Your Domoticz logging shows: (RfxTrx Interface), mine shows (RFXCOM)
Edit: never mind, you can configure the name.
Did you check the logging of Domoticz when all hardware initializes? So the startup?
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
On January 31st at 3:05 pm, I also lost the reception of all of my 4 oregon Temp sensors.
RFXCOM continued to transmit to open roller blinds for example.
That happened for the first time since I started my domoticz system 6 months ago.
I have restarted domoticz (Setup/more options/Restart system) and it works again.
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
b_weijenberg
@jmleglise
Best is to use RFXmngr and to save the receive settings in the RFXtrx:
. select the protocols for receive
. click Set Mode
. click Save Settings
if for some reason the RFXtrx restarts it will use these settings.
eagapov
Post by eagapov »
Thank you, guys, problem found and fixed :)
As b_weijenberg mentioned, it was RF flood by one of my 3 MS13 PIR sensors. When i remove battaries from all of them, one by one, normal working was revovered and i found bad PIR sensor.
