Eurodomest-972080 remote and Domoticz
cnopix
Post by cnopix »
Hello everyone,
New on the forum and Domoticz, I explain my problem :
I have a Eurodomest 972 080 Kit and I would like to run simultaneously on Domoticz + RFXCOM and with the supplied remote (Madame wants to keep the remote ^^).
I did some research on forums but I did manage to turn one of two at a time. Here's the info on the remote that I collected with RFXMNGR:
Port 1 ON
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 2
Code = DDE9AF decimal:14543278
S1- S24 = 1101 1101 1110 1001 1010 1111
Pulse = 292 usec
Signal level = 8 -56dBi
Port 1 OFF
subtype = PT2262
Sequence nbr = 2
Code = DDE9AE decimal:14543278
S1- S24 = 1101 1101 1110 1001 1010 1110
Pulse = 292 usec
How to manually add the information Domoticz to make it all in one ON / OFF function?
Thank you in advance for your answers :-)
Westcott
Re: Eurodomest-972080 remote and Domoticz
Post by Westcott »
These are the same as Energenie
That uses the COCO protocol in RFXtrx
Krijn20345
Domoticz version: 4.10717
Post by Krijn20345 »
Hi cnopix
I've got the same kit and also want to get them working simultaneously. Did you already managed the problem?
Swinkey
Post by Swinkey »
Hey cnopix,
Same problem here, Did you already managed the problem?
Thank you.
