I implemented the Domoticz_backup.sh script according the Wiki (Daily backup to external hdd) with the only changes made in IP numbers and user name and password.
Running the test via a SSH connection I get a 530 access denied message. (see below) On my NAS the user has all right's for access. Trying the path directly in a web browser works fine, including logging in on the NAS using the username and password
About to connect() to 192.168.1.40 port 21 (#0)
* Trying 192.168.1.40...
* connected
* Connected to 192.168.1.40 (192.168.1.40) port 21 (#0)
* FTP 0x174afb8 state change from STOP to WAIT220
< 220 NASFTPD Turbo station 1.3.5a Server (ProFTPD) [192.168.1.40]
> USER “user”
* FTP 0x174afb8 state change from WAIT220 to USER
< 331 Password required for “user”
> PASS “password”
* FTP 0x174afb8 state change from USER to PASS
< 530 Login incorrect.
* Access denied: 530
* Closing connection #0
Does any one have a suggestion what could be the case?
[Solved] FTP connection to NAS fails
ReneF
- Domoticz version: V2.3530
pepijn
Re: FTP connection to NAS fails
Try to remove the quotes
ReneF
Thanks Pepijn.
You're suggestion worked. Maybe a good idea to mention this in the wiki.
Secondly I discovered that the NAS does not allow to write to a directory that is not created before running this script (see below)
> CWD Domoticz_backup
< 550 Domoticz_backup: No such file or directory
* Server denied you to change to the given directory
Rene
> CWD Domoticz_backup
Rene
