No detection of static update controller (suc)
Posted: Friday 29 January 2016 9:22
by WillemK
I have a z-wave network with a static update controller (SUC) (Z-wave-me USB stick or UZB). I am using a Raspberry Pi with a razberry z-wave interface.
The SUC appears not detected in Domoticz, SUC node = 0 in the Openzwave control panel, however the z-way server software (when I use this in the Raspberry Pi instead of Domotics with ozw) does detect the SUC. What could be the issue here?
Re: No detection of static update controller (suc)
Posted: Monday 01 February 2016 17:11
by WillemK
No response/solutions?
Posted: Monday 01 February 2016 17:58
by willie-p
I've the same issue as in the openzwave software and razberry.
See also my post on adding the second controller: viewtopic.php?f=24&t=10240
Kind regards,
Will
Posted: Tuesday 02 February 2016 23:03
by WillemK
Hello Willie-p,
What I encounter is I think not the same issue as you describe. Adding Domoticz as a secondary controller was not problem, but I want to keep it as a slave without associating capabilities but only updating from the primary controller. The primary controller should be see as a SUC (Static Update Controller) by the secondary controller in openzwave but it is not. In the Openzwave control panel a "0" is shown at SUC node.
When I switch to the z-way control panel (from z-wave.me) the secondary controller sees the primary as SUC. So for the moment I can only update the secondary controller by switching from Domoticz to z-way.
I wonder whether there is a way in openzwave to change the SUC Node ID. If someone knows it, please share. Thanks in advance!
Regards,
Willem
Posted: Friday 18 November 2016 9:32
by WillemK
I still did not found a solution, still can't get a secondary domoticz controller update from the SUC.
Posted: Tuesday 10 January 2017 2:06
by jin
+1 for me...
I really need this feature since 2014... This seems a limitation of Domoticz :(
with kind regards
Posted: Saturday 27 May 2017 14:03
by WillemK
It does still not work. It is probably openzwave limitation.
Posted: Sunday 28 May 2017 11:58
by jin
That missing features make OpenZWave stack really less portable... primarily with large zwave network.
Posted: Thursday 09 November 2017 19:13
by WillemK
I still hope that this function will be added some day...
