High temperature sensor
Posted: Monday 25 January 2016 22:03
by oliviers
Can anyone recommend a temperature sensor for high temperatures (40-120°C), supported by RFXCOMM/Domoticz ?
Goal is to start an heat recovery fan in the fireplace hood as soon as the temperature reaches 40-50 degrees therein.
Of course I could do it with a simple thermostat, but I would rather do it via my home automation system...
Thanks for any hint,
Oliviers
Re: High temperature sensor
Posted: Monday 25 January 2016 22:11
by b_weijenberg
The Maverick ET-722 BBQ/smoke sensor can be used for example.
Posted: Tuesday 26 January 2016 8:30
by oliviers
That sounds like an interesting suggestion... I looked to all kind of devices, but I didn't think to a BBQ probe, I must admit ....
Posted: Tuesday 26 January 2016 8:57
by bbqkees
I have that sensor for my bbq's, indeed it works with Domoticz. (I use it to keep an eye on the smoker during long sessions).
I am not sure how long the battery will last if you keep it turned on.
You would only need the transmitter part, not the receiver. Maybe you can get it as a spare part.
But you can also use a (waterproof) DS18B20 sensor, they also go up to 125 degrees C.
It would need some additional components though.
Posted: Tuesday 26 January 2016 10:32
by oliviers
Well, if I go for that solution, I will replace the battery by a wall adapter.
Posted: Tuesday 26 April 2016 18:51
by oliviers
Just to let you know....
I'm running that sensor on its batteries for three months now.... Not showing any wekaness so far...
Posted: Wednesday 14 December 2016 22:09
by jenssen
bbqkees wrote:I have that sensor for my bbq's, indeed it works with Domoticz. (I use it to keep an eye on the smoker during long sessions).
what receiver do I need to connect this transmitter to Domoticz? Do you recommended the Maverick ET732 or the Maverick ET733? Is it seen as a temperature device within Domoticz? How fast is the temperature updated?
Thanks.
Posted: Thursday 15 December 2016 9:14
by bbqkees
I use the RFXCOM.
I have the ET732 but the ET733 seems like the follow up model.
Posted: Sunday 25 December 2016 11:43
by Roland1971
I did find the ET733 under the christmas tree today
looks and feels good !
When searching for new devices, Domoticz finds 3 new, 2 temperature sensors and 1 BBQ meter. The temperature sensors are added and displayed in the dashboard but I am not able to find the BBQ meter. Is this correct or ?
Does anyone have a solution to add the BBQ meter
Happy holidays
Posted: Saturday 22 December 2018 21:57
by Axeteg
I have a problem with the Maverick termometer.
I can see it under the "Device" tab,with correct values and everything, but when i add it, it dont show in the "Temperature" tab.
Someone else that has this problem?
