How to do reduce log interval
ricard
Post by ricard »
I would like to reduce the log interval from 5 minutes to 1 minute.
Which file of the source code do I need to modify and re-build?
Thank you
nayr
Domoticz version: github
Re: How to do reduce log interval
Post by nayr »
what?
There is no log interval.. if you dont have activity there is nothing to log.. or are you wanting higher resolution on the graphs?
ricard
Post by ricard »
Yes, I would like to have higher resolution on the graphs/data logged.
Egregius
Domoticz version: v2024.7
Post by Egregius »
I think it would be better to have a setting per switch.
I would definitely don't wanna have records of all temps and setpoints every minute. That would be over a million records a month.
ricard
Post by ricard »
My intention is to modify the code so that the interval is 1 minute instead of 5 minutes, and only log/record the value if the deviation is more than 10%.
Egregius
Post by Egregius »
I guess the graphs can't handle gaps in the timings. What else could be the reason for storing the same value every 5 minutes?
I only keep temperature data of the last 12 hours and that's 3400 records.
I like to keep the database as small as possible, seems to be much faster and stable that way. Every night I remove records of temperature, meter, percentage devices I don't care about.
ricard
Post by ricard »
Dear Egregius,
"The man who says it can't be done... shouldn't interrupt the man who is trying to do it"
I am happy to work with the source code, and I would appreciate if somebody can tell me which are the file/s that I will need to modify.
Thank you
Egregius
Post by Egregius »
Sorry for giving my opinion in a discussion board.
ricard
Post by ricard »
I couldn't find an appropriate subforum, so I wrote my question in here.
I am trying to make a Historian and I would appreciate any constructive ideas/opinions.
nayr
Post by nayr »
the only way to learn the code base is to start digging into it, it would take longer to try to explain it than it would be to just implement it.. Ive been hacking at it for a while and still dont have a solid grasp of where everything is done at.. its alot of lines to look through.
the code is all yours, let us know what you come up with.. sorry I cant help you, Ive been avoiding mucking with the datasets directly until I better understand the consequences of my actions.
ricard
Post by ricard »
I think it I can change it in the SQLHelper.cpp file.
But as you said, there is a lot of code to dig.
It would be great if someone could point to the right place.
ricard
Post by ricard »
Just in case someone is interested (which I think there will be more than one)
I have successfully changed the log interval from 5 minutes to 1 minute by changing the iShortLogInterval in the SQLServer.cpp
And then rebuilding/re-making the code
gizmocuz
Post by gizmocuz »
you have to remove 2 lines in the SQLServer.cpp and then you can change it in the database (actually the html code is also there but hidden)
	if (!GetPreferencesVar("ShortLogInterval", nValue))
		nValue = 5;
		UpdatePreferencesVar("ShortLogInterval", nValue);
then underneed remove these two lines
	if (nValue < 1)
		nValue = 5;
i probably must have some good reason not to expose this yet ?
ricard
Post by ricard »
Hi gizmocuz
Thank you for the additional information.
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
I think with the right explanation next to the option a person should have the possibility to change the value from settings. Or are there any caveats when changing to a smaller interval?
I can imagine a fast growing database and a less responsive interface due to large json requests.
Egregius
Post by Egregius »
Everyone has a specific reason for settings like this. I would't lower it, instead rise to 10 or 15 :p
Speed is more important than a graph for me.
But, as said before: the best option would be to set it for every sensor seperately.
gizmocuz
Post by gizmocuz »
there has been another approach offered on this forum, if value is different then the last value in the log, add the value
could be worth investigating by someone
Egregius
Post by Egregius »
That would even be a better solution :)
If it doesn't break the graphs that is.
In my situation I have a record every 5 minute in each room for a thermometer, a setpoint and a radiator valve. Especially for the setpoints it's very repitive data in the tables.
delchrys
Post by delchrys »
gizmocuz wrote:you have to remove 2 lines in the SQLServer.cpp and then you can change it in the database (actually the html code is also there but hidden)
		nValue = 5;
	if (nValue < 1)
		nValue = 5;
Which file do we need to edit to change logging to 1 minute, is it SQLHelper.cpp or SQLServer.cpp??
I tried it in SQLHelper.cpp and rebuild it with
gcc -c SQLHelper.cpp
And then again the:
make -j 4
But when i reboot the pi and/or reboot domoticz, i still have 5 min intervals.
Am i doing something wrong???
gizmocuz
Post by gizmocuz »
Did you also made a change in the database as mentioned ?
