Hello everyone,
I guess it's possible to read out multiple ds18b20 with piface in Domoticz?
Because i want to buy a new raspberry with piface and a couple of ds18b20 to read out temperatures in different locations in a terrarium i got for my reptiles. I will use a kaku switch to turn of the heat source, ofcourse when it's getting to hot. Short version: i want to create a thermostat for the terrarium.
Does anyone know if it's possible to accomplice this with the piface and could help me in the right direction in terms of configuration of the piface with multiple ds18b20?
Piface with a couple of ds18b20
Moderators: fantom, leecollings
- Keptenkurk
- Target OS: -
Re: Piface with a couple of ds18b20
The piface only provides digital input and outputs. It is not possible to connect ds18b20 1-wire sensors to the piface. Check the domoticz wiki / 1-wire how to get this done
/paul
/paul
Doomotic
- Domoticz version: 2.3530
Thanks, i must have misunderstood the piface/1wire thing. I will continu my search in the wiki then.
baptist
Try using some esp8266
http://www.esp8266.nu/index.php/TemperatureSensor
I have these dotted around my home for all my temperature / humidity / smoke / inputs / relay outputs / lux...
Sent from my SM-N9208 using Tapatalk
