I am building a wind speed sensor node, but I am having diffictulty's in getting it to work
The sensor I am using has a 0 to 5V analog output for windspeeds from 0 to 32,4 m/s.
So what I did right now is I took the lightsensor example code (Arduino) and changed the formula to give me the value in m/s instead of lux, this already works.
And the node sends wind in m/s to Domoticz, but Domotics thinks it is LUX (makes sense because of the S and V LIGHT_LEVEL)
But now I would also like it that my Domoticz gateway would also see it as a wind speed sensor instead of a light sensor.
So changed V_LIGHT_LEVEL and S_LIGHT_LEVEL to S_WIND and V_WIND, unfortunatly than it doenst work anymore.
I can see in the log file that the node reports itself to Domoticz but that is it.
At this moment I am running Domoticz on a RaspberryPi with build version 2.4269
Any hints/tips/help would be greatly appriciated!
Greetz Johan
(FYI I am only 4 days old with Domoticz)
S_WIND
Re: S_WIND
Did you try to delete the node (and devices), restart Domoticz and then add it again?
Re: S_WIND
When I remove the node (when available from Light) after a restart it will not automaticly come back as a windmeter.Jan80 wrote:Did you try to delete the node (and devices), restart Domoticz and then add it again?
The Domoticz log file show Arduino Sketch name and number from the windmeter but thats it than.
There is no further data beeing seen by Domoticz.
Do you have any suggestions what I can try to do?
Greetz Johan
Re: S_WIND
Are you sure the node is sending data to the gateway? You should check this with the serial monitor. Post the results.
Re: S_WIND
Here is the codebender serial data with the "LIGHT_LEVEL" Arduino code, here you can see that it is sending 11,4m/s in LUX.Jan80 wrote:Are you sure the node is sending data to the gateway? You should check this with the serial monitor. Post the results.
send: 4-4-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
read: 0-0-4 s=255,c=3,t=6,pt=0,l=1,sg=0:M
sensor started, id=4, parent=0, distance=1
send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=fail:Wind Sensor
send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:2.0
send: 4-4-0-0 s=1,c=0,t=16,pt=0,l=0,sg=0,st=ok:
11.23
send: 4-4-0-0 s=1,c=1,t=23,pt=7,l=5,sg=0,st=ok:11.2
11.39
send: 4-4-0-0 s=1,c=1,t=23,pt=7,l=5,sg=0,st=ok:11.4
11.39
11.39
send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:2.0
send: 4-4-0-0 s=1,c=0,t=9,pt=0,l=0,sg=0,st=ok:
11.23
send: 4-4-0-0 s=1,c=1,t=8,pt=7,l=5,sg=0,st=fail:11.2
11.42
send: 4-4-0-0 s=1,c=1,t=8,pt=7,l=5,sg=0,st=ok:11.4
11.39
11.39
11.39
Re: S_WIND
I found a small example code here, with a bit of modification it works
viewtopic.php?f=42&t=6306&p=42867&hilit=wind#p42867
Well at leat I am seeing a windspeed sensor and it is receiving wind data
I will modify the code a bit more and than I will upload it here for reference.
Re: S_WIND
The log you posted has nothing to to with Domoticz. It's all pure MySensors. See https://www.mysensors.org/download/serial_api_15
Re: S_WIND
Yes that is correct, but the question was also can you show the serial logJan80 wrote:The log you posted has nothing to to with Domoticz. It's all pure MySensors. See https://www.mysensors.org/download/serial_api_15
Unfortunatly the Domoticz log does not show anything with "old" sketch.
But luckely for me now it works, altough I have no idea why the "old" one did not work and that kind of does bother me.
Greetz Joahn
