Axis 207W Image
Posted: Wednesday 20 January 2016 20:30
by Martijn85
I can`t get my old Axis 207(W) camera working with Domoticz. I have found the url on this forum and this should be: http://camera-ip/axis-cgi/jpg/image.cgi
When i use this url in the browser it works fine but when i add this to domoticz the image appears one time for 1 second and then it changes to black. I also tried to changed the camera settings with anonymous login, but still no luck. I hope there is someone also useing a Axis camere to help me out.
Re: Axis 207W Image
Posted: Tuesday 26 January 2016 16:33
by mxpwr
I have the exact same issue with my axis camera. Tried everything but it never works.
Re: Axis 207W Image
Posted: Tuesday 26 January 2016 16:54
by Brutus
Try this at ImageURL: jpg/image.jpg?size=3
Re: Axis 207W Image
Posted: Tuesday 26 January 2016 18:51
by mxpwr
That doesnt work either.
When I use the url in this form, I get an image in the preview, but in domoticz I only get a black frame.
/axis-cgi/jpg/image.cgi?usr=root&pwd=pass
Re: Axis 207W Image
Posted: Tuesday 26 January 2016 19:08
by Brutus
mxpwr wrote:That doesnt work either.
This is my setup with a Axis M1054, maybe try the root user ?
Re: Axis 207W Image
Posted: Tuesday 26 January 2016 22:01
by mxpwr
Both urls work fine in the browser, but in domoticz I only get a broken link symbol.
I can paste the link of the "broken link" symbol in the browser and it loads the snapshot...
Re: Axis 207W Image
Posted: Wednesday 27 January 2016 20:58
by Martijn85
When i use this link: jpg/image.jpg?size=3 and test the conenctions it seems to work, no black screen and the image will appear. When i update the settings it`s not working anymore :?
edit: Strange, when i remove the camera and add a new one with the same settings (even with root) it also doesn`t work anymore in the preview!
edit2: When i open the link in the browser and then add the camere the preview is showing but afther i update the settings i have the same issues.
Re: Axis 207W Image
Posted: Wednesday 27 January 2016 21:14
by nayr
there is a bug ive noticed that the test button on camera add shows a broken camera, but everywhere else within domoticz it displays fine.
so before you pull out your hair thinking your camera is broke, save it and try using it.. especially if your sure the info is correct.
Re: Axis 207W Image
Posted: Sunday 07 February 2016 21:00
by clafa
I see the same problem. If I do test connection with /axis-cgi/jpg/image.cgi it just flashes my snapshot and then returns to broken camera. And downloading doesn't work either.
If I use /jpg/image.jpg?size=3 the test connection works fine but not downloading.
has camera preview been changed recently?
br
/c
