Axis 207W Image
Martijn85
Domoticz version: Stable
Axis 207W Image
Post by Martijn85 »
I can`t get my old Axis 207(W) camera working with Domoticz. I have found the url on this forum and this should be: http://camera-ip/axis-cgi/jpg/image.cgi
When i use this url in the browser it works fine but when i add this to domoticz the image appears one time for 1 second and then it changes to black. I also tried to changed the camera settings with anonymous login, but still no luck. I hope there is someone also useing a Axis camere to help me out.
mxpwr
Re: Axis 207W Image
Post by mxpwr »
I have the exact same issue with my axis camera. Tried everything but it never works.
Brutus
Re: Axis 207W Image
Post by Brutus »
Try this at ImageURL: jpg/image.jpg?size=3
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
mxpwr
Re: Axis 207W Image
Post by mxpwr »
That doesnt work either.
When I use the url in this form, I get an image in the preview, but in domoticz I only get a black frame.
/axis-cgi/jpg/image.cgi?usr=root&pwd=pass
Brutus
Re: Axis 207W Image
Post by Brutus »
mxpwr wrote:That doesnt work either.
This is my setup with a Axis M1054, maybe try the root user ?
28x Fibaro Modules
SMA Solar System
mxpwr
Re: Axis 207W Image
Post by mxpwr »
Both urls work fine in the browser, but in domoticz I only get a broken link symbol.
I can paste the link of the "broken link" symbol in the browser and it loads the snapshot...
Martijn85
Re: Axis 207W Image
Post by Martijn85 »
When i use this link: jpg/image.jpg?size=3 and test the conenctions it seems to work, no black screen and the image will appear. When i update the settings it`s not working anymore :?
edit: Strange, when i remove the camera and add a new one with the same settings (even with root) it also doesn`t work anymore in the preview!
edit2: When i open the link in the browser and then add the camere the preview is showing but afther i update the settings i have the same issues.
nayr
Domoticz version: github
Re: Axis 207W Image
Post by nayr »
there is a bug ive noticed that the test button on camera add shows a broken camera, but everywhere else within domoticz it displays fine.
so before you pull out your hair thinking your camera is broke, save it and try using it.. especially if your sure the info is correct.
clafa
Re: Axis 207W Image
Post by clafa »
I see the same problem. If I do test connection with /axis-cgi/jpg/image.cgi it just flashes my snapshot and then returns to broken camera. And downloading doesn't work either.
If I use /jpg/image.jpg?size=3 the test connection works fine but not downloading.
has camera preview been changed recently?
br
/c
