Changing from RFXtrx433 to RFXtrx433e
Posted: Wednesday 20 January 2016 0:55
by markk
I'm running Domoticz on Windows with a rfxtrx433 and have just bought a rfxtrx433e to replace it. I've tried adding this the same way as I originally added the rfxtrx433 but, although it is receiving commands, it won't send any. It seems my existing switches are still linked to the rfxtrx433. Is there a process i need to follow to make the change over?
Re: Changing from RFXtrx433 to RFXtrx433e
Posted: Wednesday 20 January 2016 13:49
by mbliek
Did you enable the right protocols on the new RFXCOM? The devices are not linked to the RFXCOM like zwave does.
You need to select the right protocols in order to switch them. Receiving is always enabled.
Posted: Wednesday 20 January 2016 14:39
by markk
Thanks for your reply.Yes, all the same protocols are enabled but I get the message below. Also, looking at the log, although it receives chimes, harmony hub signals etc, the names are missing from all the "com" switches. It seems all the "com" switches are still lnked to the old RFXcom. I think I need to change something to let the new RFXcom know they exist but I can't figure out how :?
Posted: Wednesday 20 January 2016 14:56
by mbliek
Did you try restarting your pc? Or at the hardware section, select the rfxcom and press update. Do not remove the device or every device will be removed that uses the rfxcom.
Posted: Wednesday 20 January 2016 21:04
by markk
That didn't work either :(
Enabled the new rfxcom, disabled the old one, restarted the PC, still nothing!
Posted: Wednesday 20 January 2016 21:56
by bizziebis
Every switch is connected to a hardware ID in the database. Most easy would be to edit the database and change the ID of the old rfxtrx to the new one. So every switch will work like before.
So lets say your old rfxtrx has ID 3 and your new rfxtrx has ID 6. You edit the new rfxtrx to ID 3, and the old one to 6. Afterwards you can remove the old rfxtrx in domoticz
Edit: Wait, can't you just edit the old device at the hardware tab and change the comport/USB port? You don't need to add a new hardware device, at least not in Linux.
Posted: Wednesday 20 January 2016 23:54
by markk
bizziebis wrote:Every switch is connected to a hardware ID in the database. Most easy would be to edit the database and change the ID of the old rfxtrx to the new one. So every switch will work like before.
Ha ha, brilliant. that did the trick. I didn't need to add the new hardware at all :). I removed it then did as you said. plugged the new rfxcom in, checked the com port with rfx manager, in hardware changed the com port of the old rfxcom to that of the new one and updated it. Perfect :). thanks very much for taking the time to help. Much appreciated.
