I have bought both Lacrosse and Oregon scientific temperature & humidity sensors, and my sensors are catched by a rfxtrx433e connected to a RPI with Domoticz on it.
I find discrepancies of ~0.4°C between some of the sensors ; is there a way to correct the values in Domoticz , like adding an offset for a given temperature sensor ?
If I go to "Edit" on my sensor, I can only change the name...
Thank you very much for your help
Flotheouf
Temperature differences : calibrating senors in Domoticz ?
- StanHD
Re: Temperature differences : calibrating senors in Domoticz
Do you not have this for "Edit":-?
Python:- Broadlink RM2, Sonos
- bbqkees
- Domoticz version: 4.1x
0.4 is well below their expected accuracy, even original calibrated DS18B20 sensors have an accuracy of only 0,5 degrees.
flotheouf
Ok my mistake, I was looking for this option in the "devices" tab...
You mean that the Oregon's sensors are based on DS18B20 ?
I just want to try to homogenize all my devices before using them
Thanks,
Florent
Thanks,
Florent
- bbqkees
No they are not based on those sensors but to give an idea of the accuracy of a good sensor.
You can add an adjustment value but this is just a fixed offset, it cannot improve the accuracy of the sensors.
