- galadril
- Domoticz version: latest
Re: Domoticz app 2.0
Who is using the new voice commands?
And what are the first reactions on that new feature??
- Shaggie_NB
I tried it and it is working great!!!
Thnx!!
But I stil have problems with the graphs from the Gas and CO2 meters (they won't show).
For Electricity and Temp they are working OK!
Thnx!!
Jordyboytjuh
Yes, the speech functionality works great! Maybe that the Scenes can be added as well?
I also noticed that my gas / electric p1 smart meter are working fine, but they have sometimes some drops in the graphs (couple of hours they're 0). If I look at the domoticz page on my pc, everything works fine. Is that a known problem?
Keep up the great work!
piokuc
New versio 260 on Samsung Galaxy Tab S 8.4 not workig correct. After run is blank screen. Reset nothing change
Wysłane z mojego SM-G920F przy użyciu Tapatalka
- RoadXY
- Domoticz version: 2.2331
What if you don't reset the app and just start it another time?piokuc wrote:New versio 260 on Samsung Galaxy Tab S 8.4 not workig correct. After run is blank screen. Reset nothing change
piokuc
After reset still is problem.
- RoadXY
No, no reset. Just another start of the app
piokuc
Re: RE: Re: Domoticz app 2.0
I reinstall app and problem is stillRoadXY wrote:No, no reset. Just another start of the app
- Kringloper
Do you only see the menu icon (three stripes) followed by the text dashboard?piokuc wrote:After run is blank screen.
That's what I am seeing when I start the beta version. Tried restarts, re-installs, etc. when I install the lite version it all works normal. Switches, scenes, etc. are visible.
Running on a htc 9. Unfortunately I don't have another android tablet available to test.
toutazimuth
Kringloper wrote:Do you only see the menu icon (three stripes) followed by the text dashboard?piokuc wrote:After run is blank screen.
Same problem for me with my nexus 9 tablet
But run perfectly on my nexus 5 phone
Thx a lot for this amazing app !
Smartie
Please Change Plan zu Räume
I encountered a problem with the week graphs. When i hit the week button a white screen with the grid appears and then it closes. The graphs for the day, month and year are working properly though. The week graph for my energy usage does open but only shows a straight line.
And out of curiosity: did you make any progress with enhanching the style of the graphs?
piokuc
Next problem which i found is on dashboard with center name and text. All text on grid dashboard should be center align. Now some is ok some not ok.
woody4165
Same problem here...mickmack wrote:I encountered a problem with the week graphs. When i hit the week button a white screen with the grid appears and then it closes. The graphs for the day, month and year are working properly though. The week graph for my energy usage does open but only shows a straight line.
karl8754
- Domoticz version: stable
Just wanted to add another voice for everything disappearing since the recent update (beta) on my stock Nexus 9. Nothing appears on any of the screens (plans, switches, dashboard, welcome), they're all blank.
piokuc
Also good option will be add widget with shortcut to speech command to fast use from smartphone.
Jordyboytjuh
I've also noticed why my battery was draining fast last time. It was because of the widgets. I've added 4 widgets (3 buttons, 1 energy meter), maybe it's only because of the energy meter (every 10 second refresh). A widget (which not causes battery drainage) with fast speech access would be awesome!
- galadril
This should be fixed in next release on beta!karl8754 wrote:everything disappearing since the recent update (beta) on my stock Nexus 9.
- galadril
piokuc wrote:Also good option will be add widget with shortcut to speech command to fast use from smartphone.
Ill put this on the listJordyboytjuh wrote:A widget (which not causes battery drainage) with fast speech access would be awesome!!
- galadril
You can enter translations on Crowndin:Smartie wrote:Please Change Plan zu Räume
https://crowdin.com/project/domoticz-for-android
