galadril
Domoticz version: latest
Re: Domoticz app 2.0
Post by galadril »
Who is using the new voice commands?
And what are the first reactions on that new feature??
Shaggie_NB
Post by Shaggie_NB »
I tried it and it is working great!!!
Thnx!!
But I stil have problems with the graphs from the Gas and CO2 meters (they won't show).
For Electricity and Temp they are working OK!
Jordyboytjuh
Post by Jordyboytjuh »
Yes, the speech functionality works great! Maybe that the Scenes can be added as well?
I also noticed that my gas / electric p1 smart meter are working fine, but they have sometimes some drops in the graphs (couple of hours they're 0). If I look at the domoticz page on my pc, everything works fine. Is that a known problem?
Keep up the great work!
piokuc
Post by piokuc »
New versio 260 on Samsung Galaxy Tab S 8.4 not workig correct. After run is blank screen. Reset nothing change
Wysłane z mojego SM-G920F przy użyciu Tapatalka
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
piokuc wrote:New versio 260 on Samsung Galaxy Tab S 8.4 not workig correct. After run is blank screen. Reset nothing change
What if you don't reset the app and just start it another time?
piokuc
Post by piokuc »
After reset still is problem.
RoadXY
Post by RoadXY »
No, no reset. Just another start of the app
piokuc
Re: RE: Re: Domoticz app 2.0
Post by piokuc »
RoadXY wrote:No, no reset. Just another start of the app
I reinstall app and problem is still
Kringloper
Post by Kringloper »
piokuc wrote:After run is blank screen.
Do you only see the menu icon (three stripes) followed by the text dashboard?
That's what I am seeing when I start the beta version. Tried restarts, re-installs, etc. when I install the lite version it all works normal. Switches, scenes, etc. are visible.
Running on a htc 9. Unfortunately I don't have another android tablet available to test.
toutazimuth
Post by toutazimuth »
Same problem for me with my nexus 9 tablet :(
But run perfectly on my nexus 5 phone ;)
Thx a lot for this amazing app !
Smartie
Post by Smartie »
Please Change Plan zu Räume
mickmack
Post by mickmack »
I encountered a problem with the week graphs. When i hit the week button a white screen with the grid appears and then it closes. The graphs for the day, month and year are working properly though. The week graph for my energy usage does open but only shows a straight line.
And out of curiosity: did you make any progress with enhanching the style of the graphs?
piokuc
Post by piokuc »
Next problem which i found is on dashboard with center name and text. All text on grid dashboard should be center align. Now some is ok some not ok.
woody4165
Post by woody4165 »
mickmack wrote:I encountered a problem with the week graphs. When i hit the week button a white screen with the grid appears and then it closes. The graphs for the day, month and year are working properly though. The week graph for my energy usage does open but only shows a straight line.
Same problem here...
karl8754
Domoticz version: stable
Post by karl8754 »
Just wanted to add another voice for everything disappearing since the recent update (beta) on my stock Nexus 9. Nothing appears on any of the screens (plans, switches, dashboard, welcome), they're all blank.
piokuc
Post by piokuc »
Also good option will be add widget with shortcut to speech command to fast use from smartphone.
Jordyboytjuh
I've also noticed why my battery was draining fast last time. It was because of the widgets. I've added 4 widgets (3 buttons, 1 energy meter), maybe it's only because of the energy meter (every 10 second refresh). A widget (which not causes battery drainage) with fast speech access would be awesome!
galadril
Post by galadril »
karl8754 wrote:everything disappearing since the recent update (beta) on my stock Nexus 9.
This should be fixed in next release on beta!
galadril
Post by galadril »
piokuc wrote:Also good option will be add widget with shortcut to speech command to fast use from smartphone.
Jordyboytjuh wrote:A widget (which not causes battery drainage) with fast speech access would be awesome!!
Ill put this on the list
galadril
Post by galadril »
Smartie wrote:Please Change Plan zu Räume
You can enter translations on Crowndin:
https://crowdin.com/project/domoticz-for-android
