Page 48 of 66
Posted: Monday 28 March 2016 17:29
by clubeddie
Hi Aiolos, sadly. Still no improvement. I don't get it.
I now tried the frontpage of Gerard33 and there also strange things are happening.
With only adjustments of the ip address of my domoticz i get below result
- Screenshot_1.gif (252.18 KiB) Viewed 3378 times
As you can see the temperature in Badkamer is 22, and in Garage is 18. These are the IDX codes. When i change this into a valid IDX of my environment with the correct Value of Temp and humidity. Both are gonna be empty.
Same with Garagedeur, if i change this to a valid IDX of one of my devices it also dissapear.
I gave up! I cannot understand why this simple thing isn't working at my environment.
Posted: Monday 28 March 2016 18:23
by aiolos
Do you see your devices if you go with the browser to http://[domoticzip]:[port]/json.htm?type=devices&plan=2 (or plan=0 to get all devices)?
Lookup the device you want to see on the frontpage (for example a temperature device), if it is there, the frontpage should also be able to show it.
Does the developer tools / inspect / console functionality give you any other error now? The might be something else which is wrong now (maybe also because of not-supported switch types)
Posted: Monday 28 March 2016 18:55
by clubeddie
Aiolos, i start all over again. Deleted all previous data. Opened
And started to fill in some IDX codes. I see some information right now. Also weatherforecast is working (hoorah).
I checked
/json.htm?type=devices&jsoncallback=?
And there are IDX files that are not in the room or in plan=0. Here also the IDX are shown where not 'published'. I think it's going wrong there.
I am now start building
... happy user here!
Thank you all for your help!
Posted: Monday 28 March 2016 19:00
by aiolos
Good to hear it works!
In my experience it is better to create a floor plan with only the devices you need. I experienced slow responses of Domoticz (and maybe some crashes were also related to it) when requesting all devices you have while only using a few of them. I now only put the devices I want to use in the frontpage floor plan.
Posted: Monday 28 March 2016 20:13
by M4RcO
How can in configure that ?
- Unbenannt.PNG (87.04 KiB) Viewed 3335 times
Posted: Monday 28 March 2016 20:34
by clubeddie
M4RcO wrote:Hello,
It is already in the download, this is the string i use in the frontpage_settings.js
['0', 'SunBoth', 'cell21', 'SunBoth','1','4'],
Posted: Monday 28 March 2016 20:43
by M4RcO
Then it looks like this :O
I put this in frontpage_settings.js :
['0','SunBoth', 'cell21', 'SunBoth','1','4']
- Unbenannt.PNG (82.29 KiB) Viewed 3329 times
Posted: Tuesday 29 March 2016 9:35
by clubeddie
And when you trie a different cell? I have used the default frontpage of Aiolos. No custimizations.
It looks like your cell has a custom css or no css?
Posted: Tuesday 29 March 2016 10:57
by jossie67
SwordFish wrote:I like to share my frontpage for those that want to used it. Keep in mind that I have no coding skills. At the moment it is only one page because I can't get the swipe to work. So if someone wants to try to get swiping to work
. Thanks to G3rard, its his frontpage I modified.
Frontpage.zip
I like you frontpage!
I still have issue with full screen on my Nexus 7 (2012) and how do you manage that this is allways in the front.
Posted: Tuesday 29 March 2016 17:20
by M4RcO
clubeddie wrote:And when you trie a different cell? I have used the default frontpage of Aiolos. No custimizations.
I downloaded this page, but it isn´t working because i run domoticz as Administrator.
When i start it as Normal user it works...
Why? Can you help me?
Posted: Tuesday 29 March 2016 20:34
by SwordFish
jossie67 wrote:SwordFish wrote:I like to share my frontpage for those that want to used it. Keep in mind that I have no coding skills. At the moment it is only one page because I can't get the swipe to work. So if someone wants to try to get swiping to work
Frontpage.zip
I made a shortcut on the homescreen with Chrome. I use a galaxytab3
Posted: Tuesday 29 March 2016 20:44
by M4RcO
So i tried the frontpage of Aiolos.
But it isn´t working, when i run domoticz as Administrator.
Why?
Can help me anyone ?
Posted: Wednesday 30 March 2016 13:09
by jossie67
SwordFish wrote:jossie67 wrote:SwordFish wrote:I like to share my frontpage for those that want to used it. Keep in mind that I have no coding skills. At the moment it is only one page because I can't get the swipe to work. So if someone wants to try to get swiping to work
Frontpage.zip
How do you get in full screen mode?
Posted: Wednesday 30 March 2016 14:48
by jannl
Did you create the shortcut on your homescreen?
Posted: Wednesday 30 March 2016 22:30
by floris74
i use the nexus 7 (gen1) with the shortcut with a succes for a year i guess. activateted with the camera and fullscreen with immersive fullscreeen mode. But since 2 weeks or so the page always freeze and i have to wake up the 'startbalk' to wakeup the frontpage. i havent had that problem before. i also downgraded android to 4.4 but without no luck. i consider to buy a new nexus 7, (2013) or an galaxy tab 2/3. can i see the whole frontpage without an immersive mode so it wont freeze anymore? or is there a solution for my problem?
thanks, Floris
Posted: Thursday 31 March 2016 7:01
by SwordFish
floris74 wrote:i use the nexus 7 (gen1) with the shortcut with a succes for a year i guess. activateted with the camera and fullscreen with immersive fullscreeen mode. But since 2 weeks or so the page always freeze and i have to wake up the 'startbalk' to wakeup the frontpage. i havent had that problem before. i also downgraded android to 4.4 but without no luck. i consider to buy a new nexus 7, (2013) or an galaxy tab 2/3. can i see the whole frontpage without an immersive mode so it wont freeze anymore? or is there a solution for my problem?
thanks, Floris
I have the same problem after i posted that screenshot. Now I used without immersive fullscreen, the only thing I see more is statusbar with the battery and time.
Posted: Thursday 31 March 2016 10:27
by floris74
Hey SwordFish,
which tablet do you use? and can you see the whole frontpage, even with the statusbar? In immersive mode with only the statusbar my page freezes also and i cant see the bottom of the frontpage.html
Posted: Thursday 31 March 2016 11:13
by SwordFish
floris74 wrote:Hey SwordFish,
I don't use immersive mode. I think I have a tab3.
Yes I see the whole page because I make it for my screen.
Try to adjust the scale in the index.html
Posted: Sunday 03 April 2016 21:27
by M4RcO
Why can i run Domoticz Frontpage not as Administrator ?
i have to start Domoticz as Administrator because, the system alive checker isnt working then.
Can help me anyone?
Posted: Sunday 10 April 2016 23:51
by Xroads
Hi Guys
I'm playing with this awesome frontpage from G3erard, there's one thing pusling me.
In frontpage_settings.js there is this section "<!-- Change idx of special items -->", and I just can't understand what they are for.
Could anyone explain please.
