clubeddie
Post by clubeddie »
Hi Aiolos, sadly. Still no improvement. I don't get it.
I now tried the frontpage of Gerard33 and there also strange things are happening.
With only adjustments of the ip address of my domoticz i get below result
As you can see the temperature in Badkamer is 22, and in Garage is 18. These are the IDX codes. When i change this into a valid IDX of my environment with the correct Value of Temp and humidity. Both are gonna be empty.
Same with Garagedeur, if i change this to a valid IDX of one of my devices it also dissapear.
I gave up! I cannot understand why this simple thing isn't working at my environment.
aiolos
Domoticz version: stable
Post by aiolos »
Do you see your devices if you go with the browser to http://[domoticzip]:[port]/json.htm?type=devices&plan=2 (or plan=0 to get all devices)?
Lookup the device you want to see on the frontpage (for example a temperature device), if it is there, the frontpage should also be able to show it.
Does the developer tools / inspect / console functionality give you any other error now? The might be something else which is wrong now (maybe also because of not-supported switch types)
Contributor to Dashticz
More on my Github profile
clubeddie
Post by clubeddie »
Aiolos, i start all over again. Deleted all previous data. Opened
And started to fill in some IDX codes. I see some information right now. Also weatherforecast is working (hoorah).
I checked
/json.htm?type=devices&jsoncallback=?
And there are IDX files that are not in the room or in plan=0. Here also the IDX are shown where not 'published'. I think it's going wrong there.
I am now start building :-)... happy user here!
Thank you all for your help!
aiolos
Post by aiolos »
Good to hear it works!
In my experience it is better to create a floor plan with only the devices you need. I experienced slow responses of Domoticz (and maybe some crashes were also related to it) when requesting all devices you have while only using a few of them. I now only put the devices I want to use in the frontpage floor plan.
M4RcO
Domoticz version: 3.4834
Post by M4RcO »
How can in configure that ?
Hardware: Shuttle XS35V5Pro
OS: Windows 7 Pro x64
Domoticz branch: beta
Domoticz Version: V3.5010
clubeddie
Post by clubeddie »
M4RcO wrote:Hello,
It is already in the download, this is the string i use in the frontpage_settings.js
['0', 'SunBoth', 'cell21', 'SunBoth','1','4'],
M4RcO
Post by M4RcO »
Then it looks like this :O
I put this in frontpage_settings.js :
['0','SunBoth', 'cell21', 'SunBoth','1','4']
clubeddie
Post by clubeddie »
And when you trie a different cell? I have used the default frontpage of Aiolos. No custimizations.
It looks like your cell has a custom css or no css?
jossie67
Post by jossie67 »
SwordFish wrote:I like to share my frontpage for those that want to used it. Keep in mind that I have no coding skills. At the moment it is only one page because I can't get the swipe to work. So if someone wants to try to get swiping to work ;) . Thanks to G3rard, its his frontpage I modified.
Frontpage.zip
I like you frontpage!
I still have issue with full screen on my Nexus 7 (2012) and how do you manage that this is allways in the front.
Raspberry Pi (3x)
Master Domoticz installed on a Synology
RFXCOM RFXtrx433E USB
RFLink
USB Z-Wave Mini Adapter
Mi-light
QuinLED
Landis+Gyr ZME120ACd
Kamstrup_M401
USB-IR-Schreib-Lesekopf Alecto WS1700
Watermeter with TCRT5000
Kodi
DS18B20
M4RcO
Post by M4RcO »
clubeddie wrote:And when you trie a different cell? I have used the default frontpage of Aiolos. No custimizations.
I downloaded this page, but it isn´t working because i run domoticz as Administrator.
When i start it as Normal user it works...
Why? Can you help me?
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Frontpage.zip
I made a shortcut on the homescreen with Chrome. I use a galaxytab3
M4RcO
Post by M4RcO »
So i tried the frontpage of Aiolos.
But it isn´t working, when i run domoticz as Administrator.
Why?
Can help me anyone ?
jossie67
Post by jossie67 »
SwordFish wrote:
Frontpage.zip
How do you get in full screen mode?
Raspberry Pi (3x)
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
jannl
Domoticz version: 2025.5.x
Post by jannl »
Did you create the shortcut on your homescreen?
floris74
Post by floris74 »
i use the nexus 7 (gen1) with the shortcut with a succes for a year i guess. activateted with the camera and fullscreen with immersive fullscreeen mode. But since 2 weeks or so the page always freeze and i have to wake up the 'startbalk' to wakeup the frontpage. i havent had that problem before. i also downgraded android to 4.4 but without no luck. i consider to buy a new nexus 7, (2013) or an galaxy tab 2/3. can i see the whole frontpage without an immersive mode so it wont freeze anymore? or is there a solution for my problem?
thanks, Floris
SwordFish
Post by SwordFish »
floris74 wrote:i use the nexus 7 (gen1) with the shortcut with a succes for a year i guess. activateted with the camera and fullscreen with immersive fullscreeen mode. But since 2 weeks or so the page always freeze and i have to wake up the 'startbalk' to wakeup the frontpage. i havent had that problem before. i also downgraded android to 4.4 but without no luck. i consider to buy a new nexus 7, (2013) or an galaxy tab 2/3. can i see the whole frontpage without an immersive mode so it wont freeze anymore? or is there a solution for my problem?
thanks, Floris
I have the same problem after i posted that screenshot. Now I used without immersive fullscreen, the only thing I see more is statusbar with the battery and time.
floris74
Post by floris74 »
Hey SwordFish,
which tablet do you use? and can you see the whole frontpage, even with the statusbar? In immersive mode with only the statusbar my page freezes also and i cant see the bottom of the frontpage.html
SwordFish
Post by SwordFish »
floris74 wrote:Hey SwordFish,
I don't use immersive mode. I think I have a tab3.
Yes I see the whole page because I make it for my screen.
Try to adjust the scale in the index.html
M4RcO
Post by M4RcO »
Why can i run Domoticz Frontpage not as Administrator ?
i have to start Domoticz as Administrator because, the system alive checker isnt working then.
Can help me anyone?
Xroads
Post by Xroads »
Hi Guys
I'm playing with this awesome frontpage from G3erard, there's one thing pusling me.
In frontpage_settings.js there is this section "<!-- Change idx of special items -->", and I just can't understand what they are for.
Could anyone explain please.
Raspberry pi 2
Razberry z-wave module with Fibaro dimmer, relay and pir and Dlink pir.
433mhz RFlink with 5 pcs. on/off switches
